coming from mega-20180413 Iupdated today to mega-20180428.
Surprisingly, the connection to an hidden SSID fails.
Log says: "noAP found"
Three others devices are running on mega-20180413 pretty well. I tried an update, because one one devie I could not set the resolution of the DS18B20 to 12 bit.
[edit]
I've tried out, last version with working connection to hidden SSID mega-2018-04-20
[/edit]
[edit1]
sorry, I was wrong. Alt least mega-20180421 works, I'll try more
[/edit1]
[edit2]
Definitly last working version with hidden SSID: mega-20180426
Sorry for the confusion...
[/edit2]
Hidden SSID mega-20180428
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
Re: Hidden SSID mega-20180428
On my side, ESP's are working with hidden SSID. I use static IP, maybe this is the cause.
Maybe, I'm using DHCP. Due to the fact that I have a fallback WLAN - different IP-range - to guarantee the monitoring its neccessary.
Up to now, four devices with 26.04 working perfect.
pi@raspberrypi:~ $
Hidden SSID is not enabled when connecting.
If you want to have it, could you add an issue for it?
thank you for taking care of my problem.
I'm an absolute newbie here, pls help. How and where do I open an issue? I would like to do so, as well as testing&reporting everthing you need.
Ehm, but what I don't understand, all the versions I have used up to now have had no problems with my WLAN including the version of 20180426.
[edit]
I've found it on github and I'll try my best....
[/edit]
[edit]
[/edit]
pi@raspberrypi:~ $
Users browsing this forum: Ahrefs [Bot] and 30 guests
