Hidden SSID mega-20180428
Wiki
#1 Post by Wiki » 28 Apr 2018, 17:52
coming from mega-20180413 Iupdated today to mega-20180428.
Surprisingly, the connection to an hidden SSID fails.
Log says: "noAP found"
Three others devices are running on mega-20180413 pretty well. I tried an update, because one one devie I could not set the resolution of the DS18B20 to 12 bit.
[edit]
I've tried out, last version with working connection to hidden SSID mega-2018-04-20
[/edit]
[edit1]
sorry, I was wrong. Alt least mega-20180421 works, I'll try more
[/edit1]
[edit2]
Definitly last working version with hidden SSID: mega-20180426
Sorry for the confusion...
[/edit2]
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
Rampler
Re: Hidden SSID mega-20180428
#2 Post by Rampler » 29 Apr 2018, 12:51
On my side, ESP's are working with hidden SSID. I use static IP, maybe this is the cause.
Wiki
#3 Post by Wiki » 29 Apr 2018, 22:00
Maybe, I'm using DHCP. Due to the fact that I have a fallback WLAN - different IP-range - to guarantee the monitoring its neccessary.
Up to now, four devices with 26.04 working perfect.
pi@raspberrypi:~ $
#4 Post by TD-er » 30 Apr 2018, 00:29
Hidden SSID is not enabled when connecting.
If you want to have it, could you add an issue for it?
Wiki
#5 Post by Wiki » 30 Apr 2018, 02:06
thank you for taking care of my problem.
I'm an absolute newbie here, pls help. How and where do I open an issue? I would like to do so, as well as testing&reporting everthing you need.
Ehm, but what I don't understand, all the versions I have used up to now have had no problems with my WLAN including the version of 20180426.
[edit]
I've found it on github and I'll try my best....
[/edit]
pi@raspberrypi:~ $
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 15 guests
