vcc versions of firmware
riker1
#1 Post by riker1 » 16 May 2018, 10:17
what exactly is the function of the vcc versions of the firmware?
Re: vcc versions of firmware
#2 Post by grovkillen » 16 May 2018, 11:09
If you need to monitor the battery of a battery driven unit you want to have VCC enabled. It must be done at compile time since it will take over the analog function internally.
riker1
#3 Post by riker1 » 17 May 2018, 10:01
ok understood, thanks
can it alse be used to monitor power supply from adapter?
I eperienced sometimes VCC is shown as -1
#4 Post by grovkillen » 17 May 2018, 11:47
If the variable output is "-1.0" it means that the VCC is not activated or that a reading has not been completed (could be due to incorrect cabling etc. etc.).
Micha_he
#5 Post by Micha_he » 17 May 2018, 11:50
I remember that,...
if the "Delay" (Interval) for the Vcc-System-Device is set to 0, it's the same effect ;)
#6 Post by grovkillen » 17 May 2018, 12:27
Ah, that's right. Will add that scenario to the wiki. Thanks!
Micha_he
#7 Post by Micha_he » 17 May 2018, 13:10
But TD-er had offered, that he change the behavior of the 0-delay-value of the devices, that these will be published once to the controller !?
https://github.com/letscontrolit/ESPEasy/issues/1202
#8 Post by grovkillen » 17 May 2018, 13:25
Ok, I will leave it as it is for now. It's only a notice... We'll have to do a complete update of the wiki when we release 2.1
