I guess removing Plugins works only when i compile myself. Unfortunately my Arduino IDE is a bit messed up. And i don't really know how to remove plugins.
Switching from Dimmer to Switch and back i tried. No changes
I made a
fresh install on a brand new device (
Sonoff S20) with the
newest release from yesterday. Still same strange behavior.
Green is my action via
http://192.168.168.117/control?cmd=PWM,14,XXX and everything else in this log happens automatically and i have no idea where that comes from.
527879: SW : GPIO 14 Set PWM to 334
527923: SW : Switch state 0 Output value 0
541047: WD : Uptime 9 ConnectFailures 0 FreeMem 19496
546053: SW : GPIO 14 Set PWM to 434
546122: SW : Switch state 1 Output value 255
565168: SW : GPIO 14 Set PWM to 234
565223: SW : Switch state 0 Output value 0
571047: WD : Uptime 10 ConnectFailures 0 FreeMem 18392
588345: SW : GPIO 14 Set PWM to 500
601047: WD : Uptime 10 ConnectFailures 0 FreeMem 19496
611920: FILE : Saved config.dat
612539: FILE : Saved config.dat
612618: SW : Switch state 1 Output value 255
626679: SW : GPIO 14 Set PWM to 400
626718: SW : Switch state 0 Output value 0
631047: WD : Uptime 11 ConnectFailures 0 FreeMem 18336
646543: SW : GPIO 14 Set PWM to 450
646618: SW : Switch state 1 Output value 255
This one from
Wemos D1:
67137: FILE : Saved config.dat
104925: SW : GPIO 14 Set PWM to 450
104935: SW : Switch state 0 Output value 0
111728: WIFI : Set WiFi to STA
111761: AP Mode: Client disconnected: 38:A4:ED:03:2A:24 Connected devices: 0
126396: SW : GPIO 14 Set PWM to 455
151655: SW : GPIO 14 Set PWM to 550
151735: SW : Switch state 1 Output value 0
167487: SW : GPIO 14 Set PWM to 220
167535: SW : Switch state 0 Output value 0
189070: SW : GPIO 14 Set PWM to 250
189135: SW : Switch state 1 Output value 0
Another one from
Wemos D1 where i get less errors (no clue why):
589783: SW : GPIO 14 Set PWM to 250
607561: SW : GPIO 14 Set PWM to 210
621410: SW : GPIO 14 Set PWM to 110
636397: SW : GPIO 14 Set PWM to 80
644668: SW : GPIO 14 Set PWM to 85
644691: SW : Switch state 1 Output value 255
657265: SW : GPIO 14 Set PWM to 87
657291: SW : Switch state 0 Output value 0
669244: SW : GPIO 14 Set PWM to 90
687942: SW : GPIO 14 Set PWM to 99
746029: SW : GPIO 14 Set PWM to 120
763386: SW : GPIO 14 Set PWM to 200
777290: SW : GPIO 14 Set PWM to 150
805751: SW : GPIO 14 Set PWM to 110
894583: SW : GPIO 14 Set PWM to 90
907031: SW : GPIO 14 Set PWM to 95
923608: SW : GPIO 14 Set PWM to 180
939921: SW : GPIO 14 Set PWM to 500
945688: SW : GPIO 14 Set PWM to 600
960428: SW : GPIO 14 Set PWM to 550
960491: SW : Switch state 1 Output value 255
975441: SW : GPIO 14 Set PWM to 330
975491: SW : Switch state 0 Output value 0
991872: SW : GPIO 14 Set PWM to 320
I tried it on a Sonoff Basic, on two Sonoff S20 and a brand new Wemos D1. It behaves differently, but never as it should.
Only the dimmer function gives me these headaches. I have six other Sonoff devices running (switches and sensors) since weeks without problems.
Anything else i am able to do or try? Where does it come from?
