Geiger counter settings
lavAzza
#1 Post by lavAzza » 23 May 2018, 22:41
Please help to connect Geiger counter to NodeMCU v3 with ESPEasy Mega.
I use noname Geiger counter with 5v logic, logic convertor and NodeMCU v3.
Schema
Geiger counter ----- Converter ----- NodeMCU
GND ------------------ GND | GND --- GND
5V -------------------- 5V | 3,3V ------ 3,3V
VIN ------------------- A4 | B4 --------- D3
There is no any counts in Device page.
I tryed different Debounce Time and Mode Type settings.
Geiger counter is work fine with Arduino Uno.
lavAzza
Re: Geiger counter settings
#2 Post by lavAzza » 27 May 2018, 15:11
Can anybody help?
#3 Post by grovkillen » 27 May 2018, 15:44
Have you tried any other mode except "LOW"?
#4 Post by TD-er » 28 May 2018, 22:26
100 msec debounce time does sound a bit long.
I can imagine the pulses of this Geiger counter are short, maybe a bit too short for the ESP to detect properly.
You could add a flipflop in between the ESP and the Geiger counter. Then every blip will trigger a status switch on the flipflop output, which will result in a up- or low-level period which is a lot longer.
Every detected level change reflects a count.
belgo
#5 Post by belgo » 06 Jan 2020, 14:27
hi,
i have the same project : connect a cheap Geiger counter to Domoticz with a wemos and Espeasy on it .
Did you finally found a solution to connect them together ? and want to share it ?
thanks a lot
Belgo
belgo
#6 Post by belgo » 13 Feb 2020, 20:32
hi to all,
Finally i dont find anything already done and then i'll make it myself
i use a Wemos ( ESP 8266) , a cheap geiger counter with J305 tube and a LCD 4 X 20 chars.
the ESP send data to Domoticz with JSON http instruction.
here the result .
on domoticz:
Capture d’écran 2020-02-13 à 20.30.52.png (176.29 KiB) Viewed 197 times
see you
Belgo
#7 Post by grovkillen » 13 Feb 2020, 21:19
That is really cool! Thanks for sharing.
Please enlighten us with more info on the setup.
belgo
#8 Post by belgo » 13 Feb 2020, 21:29
i'll try to take a little time to make a schematics and share my code ..
there is some little bugs to correct , i am not a good coder :-(
but someone else could probably help me to fine tune it ;-)
see you soon
Belgo
belgo
#9 Post by belgo » 16 Feb 2020, 09:47
Hi all ,
here the schematics of my geiger counter to Domoticz .
the code will follow
Belgo
belgo
#10 Post by belgo » 16 Feb 2020, 10:13
here is my code .
they a re probably some bugs on it but it's working ..
if someone wants to improve it, plz share your modification with the community .
i am waiting your feedback
Belgo
/*************ARDUINO SKETCH FOR GEIGER COUNTER******************
Author: Belgo
This sketch was writen for geiger counter cajoe to send data to domoticz ( json http )
LCD I2C Connection:
LCD SDA -> D5
LCD SCL -> D6
VCC to +5V and ground
USB powered
V-in geiger counter to D2 pin from nodemcu
// include the library code:
#include <LiquidCrystal_I2C.h>
#include <SPI.h>
#include <Wire.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#define LOG_PERIOD 15000 //Logging period in milliseconds, recommended value 15000-60000.
#define MAX_PERIOD 60000 //Maximum logging period without modifying this sketch
#define PERIOD 60000.0 // (60 sec) one minute measure period
// Conversion factor - CPM to uSV/h
#define CONV_FACTOR 0.00812
const char* ssid = "your_ssid_wifi";
const char* password = "your_wifi_password";
const char* host = "192.168.1.100"; // ip of your domoticz server
const int port = 8080; // ip port of your domoticz server
const int watchdog = 60000; // Fréquence d'envoi des données à Domoticz - Frequency of sending data to Domoticz
//unsigned long previousMillis = millis();
volatile unsigned long CNT; // variable for counting interrupts from dosimeter
unsigned long counts; //variable for GM Tube events
unsigned long cpm; //variable for CPM
unsigned int multiplier; //variable for calculation CPM in this sketch
unsigned long previousMillis; //variable for time measurement
unsigned long dispPeriod; // variable for measuring time
unsigned long CPM; // variable for measuring CPM
float radiationValue = 0.0;
const int inputPin = 4; // pin D2 is VIN on geiger counter
// initialize the library with the numbers of the interface pins
LiquidCrystal_I2C lcd(0x27,16,2);
HTTPClient http;
void setup() { // setup
Wire.begin(D5,D6); // pins SDA and SCL of your i2c LCD screen
Serial.begin(115200);
lcd.begin(20, 4);
lcd.backlight();
lcd.home();
lcd.setCursor(3, 0); // Move the cursor at origin
lcd.print("Geiger Counter");
lcd.setCursor(0, 2);
lcd.print("CPM = ");
lcd.setCursor(0, 1);
lcd.print("Pulse = ");
lcd.setCursor(0, 3);
lcd.print("uSv/h = ");
Serial.println("Connecting Wifi...");
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.print(WiFi.localIP());
CNT = 0;
CPM = 0;
dispPeriod = 0;
attachInterrupt(digitalPinToInterrupt(inputPin), GetEvent, FALLING); // Define interrupt D2 on falling edge
Serial.println("Start counter");
int value = 0;
void loop() { // main loop
if (millis() >=dispPeriod + PERIOD) { // If one minute is over
cleanDisplay(); // Clear LCD
lcd.setCursor(9, 1);
lcd.print(" ");
CPM = CNT;
if(WiFi.status() != WL_CONNECTED) {
Serial.println("WiFi not connected !");
} else {
Serial.println("Send data to Domoticz");
String url = "/json.htm?type=command&param=udevice&idx=73&nvalue=0&svalue=";
url += String(CPM); url += ";";
sendDomoticz(url);
lcd.setCursor(9, 2);
lcd.print(CPM); //Display CPM
Serial.println(CPM);
radiationValue = CPM * CONV_FACTOR;
lcd.setCursor(9, 3);
lcd.print(radiationValue); //Display usvr/h
CNT = 0;
dispPeriod = millis();
ICACHE_RAM_ATTR void GetEvent(){ // Get Event from Device
CNT++;
lcd.print(CNT); //Display CNT
void cleanDisplay (){ // Clear LCD routine
void sendDomoticz(String url){
Serial.print("connecting to ");
Serial.println(host);
Serial.print("Requesting URL: ");
Serial.println(url);
http.begin(host,port,url);
int httpCode = http.GET();
if (httpCode) {
if (httpCode == 200) {
String payload = http.getString();
Serial.println("Domoticz response ");
Serial.println(payload);
Serial.println("closing connection");
http.end();
fluppie
#11 Post by fluppie » 17 Feb 2020, 09:47
Cool, consider uploading your data to Radmon https://radmon.org
This is mine: https://radmon.org/radmon.php?function= ... fluppie007
http://www.radmon.org/radmon.php?function=submit&user=RADMONUSERNAME&password=RADMONPOSTPASSWD&value=CPMVALUE&unit=CPM
You have to change:
RADMONUSERNAME
RADMONPOSTPASSWD
CPMVALUE
chemmex
#12 Post by chemmex » 17 Feb 2020, 22:03
I get similar functionality using ESPEasy with counter plugin and single gpio. Data is uploaded to mqtt broker every minute, then processed in Node-Red and visualised in Grafana.
Users browsing this forum: No registered users and 5 guests
