sunrise/sunset to be used in rule
TungstenE2
#1 Post by TungstenE2 » 30 May 2018, 08:35
Hi all,
I would like to use sunrise/sunset time in a rule (eg sunrise + 30min) on a Wemos D1 mini using latest mega build.
How to do this? An external HTTP request would be good, but not to a lokal controler.
I want to be independent from another controler.
Any ideas or tipps?
thx
enesbcs
Re: sunrise/sunset to be used in rule
#2 Post by enesbcs » 01 Jun 2018, 13:48
TungstenE2 wrote: 30 May 2018, 08:35 Hi all,
Any ideas or tipps?
thx
You need to know the date and time at least (NTP or RTC), and you based on it you could use something like this library:
https://github.com/dmkishi/Dusk2Dawn
papperone
#3 Post by papperone » 01 Jun 2018, 16:45
enesbcs wrote: 01 Jun 2018, 13:48
Any ideas or tipps?
thx
you need as well Longitude and Latitute, I think it's too much to implement this in EspEasy, I do this already for my garden lights but I do it in my NodeRed@RasPi :mrgreen:
#4 Post by TD-er » 01 Jun 2018, 22:32
I think it is a useful feature, so could you add an issue for it?
hooijschuur
#6 Post by hooijschuur » 01 Jul 2018, 18:21
Is IT also possible tot post An example rule
There are examples but not for Sunset etc.
TungstenE2
#7 Post by TungstenE2 » 04 Jul 2018, 08:41
I was just about to test it.
New %sunrise% and %sunset% variables were added, but I am not sure about the syntax to be used in rules.
Is there a way to test the variables?
https://www.letscontrolit.com/wiki/inde ... _Variables
TungstenE2
#8 Post by TungstenE2 » 04 Jul 2018, 14:47
could someone give an example rule how to use %sunrise% and %sunset% variables?
on this page nothing is mentioned on how to use variables:
https://www.letscontrolit.com/wiki/inde ... rial_Rules
would this be something like this?
on  %sunrise% do
 if <test>
   <action>
   <action>
enesbcs
#9 Post by enesbcs » 04 Jul 2018, 18:04
TungstenE2 wrote: 04 Jul 2018, 14:47 could someone give an example rule how to use %sunrise% and %sunset% variables?
on  %sunrise% do
 if <test>
   <action>
   <action>
I am pretty sure that variables do not ment to be used in that way.
I think that Clock#Time event need to be used:
https://www.letscontrolit.com/wiki/inde ... .29_events
xury
#10 Post by xury » 04 Jul 2018, 22:17
Perhaps that way:
on Clock#Time=All,%sunrise% do
 if <test>
   <action>
   <action>
TungstenE2
#11 Post by TungstenE2 » 06 Jul 2018, 12:45
this is working great! thx!
 On Clock#Time=All,%sunrise% do
   <action>
That makes it possible to do something at sunrise or sunset and also start a timer to do something at those moments + N seconds.
//at sunrise time set timer1 for 1 hour
        timerSet,1,3600
//When Timer1 expires, <action>
 On Rules#Timer=1 do
    <action>
 //at sunset set timer2 for 0,5 hour
On Clock#Time=All,%sunset% do
        timerSet,2,1800
//When Timer2 expires,  <action>
 On Rules#Timer=2 do
    <action>
reliable
#12 Post by reliable » 09 Nov 2018, 11:00
Hey.
I would like to use the state of sunrise or sunset when reloading ESP.
I write this rule:
On System#Wake do
  if[Clock#Time=All,%sunrise%]=1
    TaskValueSet 4,3,0
On System#Wake do
  if[Clock#Time=All,%sunset%]=1
    TaskValueSet 4,3,1
but it does not work.
Tell me how to write the rules correctly?
#13 Post by grovkillen » 09 Nov 2018, 12:24
Try this one instead:
On Time#Initialized do
  if %systime%>%sunrise% and %systime%<%sunset%
    TaskValueSet,4,3,0
    TaskValueSet,4,3,1
Just as an example. I really think it would be unique if you have the system booted at the exact minute of either sunset or sunrise...
Or if you want the rule to check each minute:
    TaskValueSet 4,3,0
    TaskValueSet 4,3,1
I think that last rule should work.. haven't tested it myself though.
reliable
#14 Post by reliable » 10 Nov 2018, 11:26
Thanks for the help. It really works as I need!
#15 Post by grovkillen » 10 Nov 2018, 11:42
Great, thanks for the feedback.
