GPIO after Sleep
henfri
GPIO after Sleep
#1 Post by henfri » 04 Jun 2018, 21:45
I am using this Rule
on shpy#HintertuerZiel=1 do
  Publish %sysname%/setze,1
  gpio,15,1
  delay 100
  gpio,15,0
on shpy#HintertuerZiel=0 do
  Publish %sysname%/setze,0
  gpio,13,1
  delay 100
  gpio,13,0
and deep-sleep. shpy#HintertuerZiel is set/triggered by MQTT.
The rule is executed and I see the message "%sysname%/setze,0" via MQTT, bu it seems that the gpio is not set to 1/0.
Is there anything I am missing?
Then I set the value via MQTT while the system is not in Sleep, everything works. But when sending it while in Sleep, the rule *is* executed (otherwise I would not see the message "%sysname%/setze,0". Only the GPIO part does not work.
Greetings,
Hendrik
toffel969
Re: GPIO after Sleep
#2 Post by toffel969 » 05 Jun 2018, 12:41
henfri wrote: 04 Jun 2018, 21:45 Hello,
  gpio,15,1
  delay 100
  gpio,15,0
  gpio,13,1
  delay 100
  gpio,13,0
Greetings,
Hendrik
Two ideas :
1. The 100ms delay is too short to notice the GPIO changing. That depends on what is connected to the GPIOs. It will only go high for 0,1 sec.
2. Try and use pulse commands:
pulse,15,1,100
pulse,13,1,100
Users browsing this forum: Google [Bot] and 131 guests
