espeasy RFID-RC522 with Android APP
smartesp
#1 Post by smartesp » 18 Jun 2018, 15:20
sorry my english is not good :(
google translate =
You can process the RFID code that is read from the android application, and the process that you do is send the esp8266 to the memory of the nodemcus so that you can register the operation for the RFID code you have selected and send the esp the operation which is done. It does not matter whether the phone is left open or not
Example = In practice, when you register the following RFID code as the authorization, it will do it every time it reads the code.
Through RFID code, many operations can be easily performed on the application and also on the esp.
example2 = give the trigger for the code for the RFID but after that time many algorithms like this can be produced.
also if the RFID code is registered through the application, the information will be given to the screen name, picture, authority etc.
