Many thanks for updated release. Great.
Martinus wrote:R64 is available for download on github, beware that it's development stuff...
Experimental: Added simple json interface to retrieve sensor data using http
use http://<esp ip>/json to collect sensor data, will return a json object array
use http://<esp ip>/json?tasknr=<task number> to collect sensor data form a single sensor, returns a single json object
Experimental: Prepare tasks for remote data feed (Work in progress...)
This may bring something like a "global" available sensor. So connect a light sensor to one unit and all other ESP units will also get the data as a "virtual sensor". So you can display outside temp on an inside ESP unit or stuff like that. Or use the level control to turn on something based on data from a remote ESP unit. All without using a controller.
Added %uptime% as variable for display
To be used for LCD/OLED display
/color]
@mkotek, let me know if it solves your issues.
Have fun experimenting, can't promise that it's stable...
Have ESP-12E currently running more than 800 minutes without restart after I upgraded today night (no logging to web, serial, only logging level 2 to to syslog server, OLED 1306, SI7021, BHT1750, BMP1800 and DS18b20 connected on test bet). Like json features and uptime for display. Please, did you consider adding "dummy" sensor for monitoring uptime and additional system parameters? Idea is to have such sensor for troubleshooting, tracking restarts etc. which make sense once we are able to pull sensor values with json now.
Would it be please possible to add some flag for selected display line that this one is not update (cleaned etc.) by ESP itself but externally (pushed some text via other system etc.)
Thank you,
Zd.
