Hi I am trying to experiment with Sonoff S20 smart socket ans ESP easy but I can't find any tutorial how to flash it from linux. Is it possible to do that? And If it is How can I do it?
Flash ESPeasy from linux
Re: Flash ESPeasy from linux
PlatformIO is also running from Linux and the flash tool used is ESPtool, which is a Python program. https://github.com/espressif/esptool
So it should work just fine in Linux.
PlatformIO can be combined with Atom or Visual Studio Code (both available in Linux), which can be used to build your own.
Flashing pre-built versions can be written to the ESP board using ESPtool.py
https://diyprojects.io/esp-easy-flash- ... y-esp8266/
For example my command:
esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash -fm dio -fs 32m 0x00000 ESPEasy_R120_4096.bin
Users browsing this forum: No registered users and 89 guests
