Relay recovery last state after power failure
Jufo
#1 Post by Jufo » 21 Aug 2018, 21:07
How to read the status of relays from Domoticz during booting ESP Easy ? and set the relay in ESP Easy ?
Best Regards,
Robert
papperone
Re: Relay recovery last state after power failure
#2 Post by papperone » 21 Aug 2018, 21:22
you must use MQTT and use the message persistance features in order to do this (I have this feature in some of my modules even thou I don't use Domoticz)
toffel969
#3 Post by toffel969 » 23 Aug 2018, 09:58
papperone wrote:
21 Aug 2018, 21:22
To clarify, papperone says you must activate the "MQTT retain" feature on the advanced tab.
papperone
#4 Post by papperone » 23 Aug 2018, 13:31
toffel969 wrote:
23 Aug 2018, 09:58
papperone wrote:
21 Aug 2018, 21:22
yes indeed, thanks for clarification, and as well in all devices that can send that message!
(in my case I can toggle a switch from the GUI which runs on a RaspberryPi and those message must be sent as well with the retain activated else the setup will not work properly!)
Users browsing this forum: No registered users and 49 guests
