How to disable rule at a specific time ?
DaveS
#1 Post by DaveS » 22 Aug 2018, 19:02
Hi All,
How can I disable the rule below every saturday from 16:00 till 23:00 only,every other day rule must be active.
on Pir_Sensor#Pir=1 do
if [LDR#Analog]<500
Publish RGB/0017F169/color/set,200,200,200
Publish RGB/0017F169/brightness/set,200
Publish RGB/0017F169/brightness/set,0
NTP has been setup and has synched with internet time server.
Thanks to all the devs for this brilliant firmware,have many nodes running espeasy and all are rock solid !
Dave
Re: How to disable rule at a specific time ?
#2 Post by TD-er » 23 Aug 2018, 02:19
Maybe this entry on the wiki can be helpful for you?
https://www.letscontrolit.com/wiki/inde ... Rules#Time
DaveS
#3 Post by DaveS » 23 Aug 2018, 17:59
I saw that but it details how to enable a rule or some operation,not disabling a rule.
I understand the day and time configuration but do not know how to implement the disabling of the rule between the 2 times
I will search further then.
#4 Post by grovkillen » 23 Aug 2018, 18:19
Can't you use a dummy variable and a if statement that will execute the rule of the dummy variable is set to zero?
#5 Post by TD-er » 23 Aug 2018, 18:50
DaveS wrote:
23 Aug 2018, 17:59
Can't you use a "else" part?
Like "if <sunday> do... else ..." ?
I am not really familiar in the rules language.
papperone
#6 Post by papperone » 24 Aug 2018, 08:46
I think the rules are ok for simple timing setup, when it comes to more complex and/or weekly I prefer to move out from ESPeasy as it's not as flexible as needed and the rules can becaome way too complex and probably cosume lots of CPU.
As well without nested IFs the overall setup of combined criteria is as well not somethign easy to write and maintain.
PS: having all my devices communicating via MQTT setup on my RaspPi, I installed as well NodeRed and with this last one creating complex rules is a piece of cake !
toffel969
#7 Post by toffel969 » 24 Aug 2018, 09:45
grovkillen wrote:
23 Aug 2018, 18:19
I agree that's a viable route
Lets assume a dummy device on Task 8, called Sat#dummy
On Clock#Time=Sat,16:00 do
Taskvalueset,8,1,1
On Clock#Time=Sat,23:00 do
Taskvalueset,8,1,0
if [LDR#Analog]<500 AND [Sat#dummy]=0
DaveS
#8 Post by DaveS » 24 Aug 2018, 17:35
Thank you Toffel969,
That is exactly what I want to achieve.
Will try it.
Dave
papperone
#9 Post by papperone » 24 Aug 2018, 20:01
it works as far as the module does not reboot for any given reason on saturday between 16:00 and 23:00 :|
#10 Post by grovkillen » 24 Aug 2018, 20:21
I would do a check right on system#boot and set the dummy accordingly.
toffel969
#11 Post by toffel969 » 24 Aug 2018, 22:53
papperone wrote:
24 Aug 2018, 20:01
Agreed, thats a flaw.
#12 Post by grovkillen » 24 Aug 2018, 23:04
toffel969 wrote:
24 Aug 2018, 22:53
papperone wrote:
24 Aug 2018, 20:01
On System#Boot do
 TaskValueSet,8,2,[%sysweekday%][%syshour%]
 Event,SetDummy
EndOn
On SetDummy do
 If [Set#Dummy2]<116 OR [Set#Dummy2]>123
  TaskValueSet,8,2,1
 Else
  TaskValueSet,8,2,0
 EndIf
EndOn
#13 Post by grovkillen » 24 Aug 2018, 23:14
Maybe change system#boot to
Time#Initialized
toffel969
#14 Post by toffel969 » 24 Aug 2018, 23:16
grovkillen wrote:
24 Aug 2018, 23:04
toffel969 wrote:
24 Aug 2018, 22:53
papperone wrote:
24 Aug 2018, 20:01
On System#Boot do
 TaskValueSet,8,3,[%syshour%]
 TaskValueSet,8,4,[Sat#Dummy2][Sat#Dummy3]
 Event,SetDummy
EndOn
On SetDummy do
 If [Set#Dummy]<716 AND [Set#Dummy]>723
  TaskValueSet,8,2,1
 Else
  TaskValueSet,8,2,0
 EndIf
EndOn
Isn't that only triggered on boot ? So you need this rule in addition to the before mentioned. Also I think the taskvalueset should be 8,1,1/0
Other than that it makes the setup a lot more robust. It's an elegant way to achieve reboot proof behaviour. I was thinking about a clock#time=Sat,**:** combined with systime check to set the dummy.... " ESP on Saturdays you must check every minute if it's between 7 or 23 o clock and set the dummy :mrgreen: :ugeek:
#15 Post by grovkillen » 24 Aug 2018, 23:17
I updated the post and suggested the Time#Initialized event instead :)
#16 Post by grovkillen » 24 Aug 2018, 23:18
And it's a add on to your splendid rule that you suggested. Thumbs up!
#17 Post by grovkillen » 24 Aug 2018, 23:29
And please bear in mind that this is me "coding" a rule on my phone on a Friday evening after two beers down :P
toffel969
#18 Post by toffel969 » 24 Aug 2018, 23:31
grovkillen wrote:
24 Aug 2018, 23:29
:-) almost the same here. Just have a check on the taskvalueset,8,2,1 at the and. I'm almost sure it must be 8,1,1
toffel969
#19 Post by toffel969 » 24 Aug 2018, 23:32
grovkillen wrote:
24 Aug 2018, 23:18
As splendid as sophisticated :lol:
#20 Post by grovkillen » 25 Aug 2018, 07:47
On Time#Initialized do
 TaskValueSet,8,2,[%sysweekday%][%syshour%][%sysmin%]
 Event,SetDummy
EndOn
On SetDummy do
 If [Set#Dummy2]<71600 OR [Set#Dummy2]>72300
  TaskValueSet,8,1,1
 Else
  TaskValueSet,8,1,0
 EndIf
EndOn
 Taskvalueset,8,1,1
 Taskvalueset,8,1,0
That would be the entire rule set? :)
toffel969
#21 Post by toffel969 » 25 Aug 2018, 09:49
grovkillen wrote:
25 Aug 2018, 07:47
 Event,SetDummy
EndOn
On SetDummy do
  TaskValueSet,8,1,1
 Else
  TaskValueSet,8,1,0
 EndIf
EndOn
 Taskvalueset,8,1,1
 Taskvalueset,8,1,0
Looks perfect to me.
DaveS
#22 Post by DaveS » 27 Aug 2018, 17:56
TaskValueSet 3, 1, 1
On Clock#Time=Sat,22:00 do
TaskValueSet 3, 1, 0
   if [LDR#Analog]>1000 AND [Saturday#Inhibit]=0
on Pir_Sensor#Pir=0 do
      Publish RGB/0017F169/state/set,OFF
The rule above is working,good point regarding the node rebooting,will sort that.
Edited original rule a bit as I need to publish Publish RGB/0017F169/state/set,OFF when the PIR timed out after no motion detected.
This rule publishes all the time whether PIR state is 0 or 1
Can this constant spamming of the broker cause slower response time or is that not going to be a problem ?
There are 3 other nodes that publish frequently on my network also.
Thanks for the advise.
toffel969
#23 Post by toffel969 » 27 Aug 2018, 23:52
DaveS wrote:
27 Aug 2018, 17:56
What is the delay setting on the PIR switch device? If it is not 0, thats what will happen.
DaveS
#24 Post by DaveS » 28 Aug 2018, 17:50
The PIR delay is set to 1 as I wanted a quick response once motion is detected.
Will this constant publishing slow broker response down at all ?
Openhab and mosquitto broker is running on a Pi 2.
Thanks again for the help chaps !
#25 Post by grovkillen » 28 Aug 2018, 17:53
The publishing will not be a problem for the broker. BUT if you set the delay to 0 (i.e. disable) will make the unit publish a change instantaneous.
toffel969
#26 Post by toffel969 » 29 Aug 2018, 07:48
DaveS wrote:
28 Aug 2018, 17:50
Ya just set that delay to 0 and the unit will behave the way you want.
DaveS
#27 Post by DaveS » 28 Sep 2018, 20:08
These rules are working well but publish all the time to broker.
Is there a way to change the rules so that ESP easy will only publish once on Pir_Sensor state change ?
#28 Post by grovkillen » 28 Sep 2018, 21:19
You could use a dummy and toggle that one only if the pir changes from 1->0 or 0->1. So prior to publish check that dummy and if it is 1 publish and then set it to 0.
DaveS
#29 Post by DaveS » 01 Oct 2018, 17:45
Good idea,will set it up like that.
Thank you
