TSOP4838 no data read IR
riker1
#1 Post by riker1 » 27 Aug 2018, 18:50
I did connect the TSOP receiver
but it does not catch and data.
What could be wrong?
thanks
running: ESP_Easy_mega-20180516_test_ESP8266_4096_VCC.bin
on wemos mini
I followed: https://www.letscontrolit.com/wiki/index.php/IR
Re: TSOP4838 no data read IR
#2 Post by TD-er » 27 Aug 2018, 19:58
To what pin do you connect the receiver?
And have you selected the pull-up?
Not all pins support pull-up and for some it may be on a board which has a pull-down resistor?
Also the TSOP4838 is for 38 kHz applications. Make sure your remote uses that frequency.
From the datasheet:
The TSOP22.., TSOP48.. series devices are provided
primarily for compatibility with old AGC2 designs. New
designs should prefer the TSOP24.., TSOP44.. series
containing the newer AGC4.
riker1
#3 Post by riker1 » 27 Aug 2018, 20:33
I connected it to D4 with pull up.
I just tried irdump in arduino , same ir receiver, there it works
riker1
#4 Post by riker1 » 28 Aug 2018, 09:05
finaly I got a value, but what is this?
3775222700
would have expected something like
protocol,
data
bit
etc.
as in LIRC
#5 Post by TD-er » 29 Aug 2018, 13:24
In the last update, the IR library has been updated.
This allows for a lot more devices to be decoded. Even so many you will probably have to disable the ones you don't use to get the resources manageable and some decoding functions may affect eachother. (as stated in the readme of that library)
I also moved the IR plugin to a separate build (with IR in the name).
I guess showing such a decimal value means it wasn't able to decode it properly?
riker1
#6 Post by riker1 » 29 Aug 2018, 16:48
hi,
do you have a exapmle output for a correct decoded IR signal?
will it be similar to IRDUMP.ino?
#7 Post by TD-er » 29 Aug 2018, 17:20
I don't have one. I just merged the pull request made by someone else.
I don't use IR myself at this moment.
#8 Post by Shardan » 29 Aug 2018, 18:02
riker1 wrote:
28 Aug 2018, 09:05
3775222700
protocol,
data
bit
etc.
as in LIRC
I didn't test the new version yet.
The older versions just give back these numbers.
riker1
#9 Post by riker1 » 29 Aug 2018, 18:45
I used the newest version
but do not know how to use those numbers?
#10 Post by Shardan » 29 Aug 2018, 21:46
riker1 wrote:
29 Aug 2018, 18:45
Well i made that easy with my home controller (FHEM).
It's just a small program that does a
"If <number> then do <action>"
That works quite nice, easier then parsing all these Coding, length and so on parameters
riker1
#11 Post by riker1 » 30 Aug 2018, 13:48
I do not understand, fhem is expecting a protocol , data, bit for an irsend command.
in espeasy I think it is the same
irsend,Protocol, data, bit
so how do you phrase the
in detail?
#12 Post by Shardan » 30 Aug 2018, 18:16
riker1 wrote:
30 Aug 2018, 13:48
in detail?
You're mixing up sending and receiving.
For sending IR codes you need the "irsend,Protocol, data, bit" syntax.
With receiving the TSOPxxxx is just a sensor as every other sensor.
It just gives back this specific number.
As it is possible to use your own code snippets with FHEM I just tested
which number is given with which key from an old IR remote and
made some IF-THEN to start some actions from FHEM.
FHEM has it's own command if you don't want to code your own PERL code.
Check
https://fhem.de/commandref.html#DOIF
for more info.
riker1
#13 Post by riker1 » 30 Aug 2018, 20:21
ok understood.
thanks
oisisi
#14 Post by oisisi » 11 Sep 2018, 18:10
To revive this: When I use a recent binary build which includes the IR library and plugins I can see in the log that codes are received and recognized but the MQTT payload always contains "0":
515390 : IR: Encoding  : NEC
Code      : 1FEA05F (32 bits)
515416 : MQTT : home/environment/esp031/irin/ir 0
I have the suspicion that there might be a bug. I'd gladly help with hunting it down.
Edit: I flashed an older version, ESPEasy_mega-20180519, and IR is working.
oisisi
#15 Post by oisisi » 12 Sep 2018, 21:13
Found the issue, modest pull request entered.
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
