Write to a local file
rayE
#1 Post by rayE » 02 Sep 2018, 13:19
Hi All,
Is there anyway to write to a local file onboard the ESP unit? I want to log some data once a month that may accumulate up to 10Kb in total, the idea is to write this to a local text file onboard the ESP unit, im guessing config.dat serve's a similar mechanism?
Ray
Re: Write to a local file
#2 Post by grovkillen » 02 Sep 2018, 13:37
Yes it's possible using a variable dump (CSV) to SD card.
https://github.com/letscontrolit/ESPEasy/pull/429
whatsupskip
#3 Post by whatsupskip » 12 Nov 2018, 01:04
Does this mean the SD card plugin is not part of one of the current firmware builds?
#4 Post by grovkillen » 12 Nov 2018, 06:48
It's not a plugin but a separate build.
