error message device name is not unique, conflicts with task ID #1
strangwise I am getting the error message.
Do know know what task #1 is and how to change it?
"devise name is not unique, conflicts with task ID #1
No duplicate device names set.
any hints?
any hints?
- Screenshot from 2018-09-03 08-17-03.png (8.14 KiB) Viewed 6937 times
Re: error message device name is not unique, conflicts with task ID #1
Do you have a blank name on task number 1?
actually where do I edit task #1?
Is this a rule?
which tab is this?
thx
Is this a rule?
which tab is this?
thx
Devices are setup in one of twelve tasks. So Task 1 is the first on the list found under devices.
Ah ok, devices at handled in task
actually device 1 is bank, was always blank I think.
looks like the name of device 2 is stored somewhere.
when I change the name it is ok, error gone.
but I need the old name in fhem, (to avoid changes there)
Try name the task 1 to something you don't need to have it enabled.
I deleted id 2 (having the conflixt with #id 1)
submitted an empty id1 now saysing having a conflixt with id#6 which is and was always empty.
running mega-20180826 test
empty id 6 is saying conflict with id 1 now - which is now a new device
But what name do you have?
sane with firmware mega-20180826 normal
no error when using: mega-20180409-normal
That version is not doing any check. Please provide me a screenshot of you task list.
ok, again firmware applied.
mega-20180826
normal version
Firmware
Build 20102 - Mega
Libraries ESP82xx Core 00000000, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3
GIT version mega-20180826
Plugins 46 [Normal]
Build Md5 68b5a4e37d60a2651976a1c4178e370
Md5 check passed.
Build time Aug 26 2018 02:14:44
Binary filename ESP_Easy_mega-20180826_normal_ESP8266_4096.bin
mega-20180826
normal version
Firmware
Build 20102 - Mega
Plugins 46 [Normal]
Md5 check passed.
- Screenshot from 2018-09-03 10-28-00.png (70.34 KiB) Viewed 7112 times
- Screenshot from 2018-09-03 10-28-14.png (62.5 KiB) Viewed 7112 times
- Screenshot from 2018-09-03 10-28-34.png (33.49 KiB) Viewed 7112 times
If you rename task one to PIR160test does it still show the error?
no a new name for task 1 is not showing the error.
somehow PIR160 is stored in some place
I just have to avoid renaming PIR160 , this is causing problem - effort in fhem to check and redesign actions
I would suggest open the task number 6 and rename it to something to make it overwrite the name PIR160 which is somehow left there. I will report this as a bug.
yes this worked.
renaming device 6
saving it
deleting it
error is gone.
yes this worked.
renaming device 6
saving it
deleting it
error is gone.
Great, that is definitely a bug. I got it reported.
Users browsing this forum: No registered users and 140 guests
