bug 9999 ESP Domoticz IDX
Dear developers...
I do have my idx for Domoticz above the 10000..
Only i cannot use the espeasy software any more.
Because the espeasy still counts to 9999...
So please a solution....
Re: bug 9999 ESP Domoticz IDX
Thanks for putting on the GitHub tracker
yeah finaly got the sonoff working..
And then i get this error grrr.
Sometimes have a lot of patients for the hobby ...
We hope to be able to spend more time on this project very soon. You might have read
mm
o i did not read.. only i do have a lot respect for the developers so..
I think i have to wait
Do you have any idea of the maximum value the Domoticz IDX can be?
mmm i think Gizmocuz [ from Domoticz ]can make it to 1.000.000
Now i am obove the 12000 [ my new devices was standing on for months in Domoticz, so i was counting all the neigbours car sensors etc etc ]
I looked at the source code and the web interface has this limit set (I knew I changed it already a while ago)
999999999
Look for this line in WebServer.ino:
addNumericBox(id, Settings.TaskDeviceID[controllerNr][taskIndex], 0, 999999999); // Looks like it is an unsigned int, so could be up to 4 bln.
Ah, found some limit in P029_Output. There it is also checking for a limit of 9999.
mmm
How can i found this in my data?.
Or how can i change this?
Do i need to reflash?
Or is there on git a change possible?
So i can do a OTA?
So i can do a OTA?
I have already changed stuff I think may be related to this and merged it.
It should be included in tomorrow's build.
can you please tell me how i can update to this newer version?
Without flash? ota? or?
Thanks!!!
Thanks!!!
Depending on the amount of memory on the ESP node.
If 1M, then you will have to reconnect the flash tool, since the current image size is a bit too big for OTA (maybe 1-step OTA?)
If you have 4M flash, then you could try OTA.
Just select the new firmware bin file from the web interface.
Thanks..
Give it a try..
Sonoff basic is 1mb?
So think a better clean flash
Give it a try..
Yep, the Sonoff basic is 1 MB (ESP8266)
Users browsing this forum: Ahrefs [Bot] and 146 guests
