prevent a timer restart before expiration
jopare
#1 Post by jopare » 05 Nov 2018, 22:07
Hi, I trigger a relay with a radar motion sensor to switch a light on for a certain time.
Unfortunately the timer becomes restartet before his expiration whenever the motion sensor sends a signal.
I want to prevent this so that the timer can only be restarted after he has expired. Found nothing helpful
neither here nor in the docu. Any help will be appreciated. Thx.
on Radar#send do
if [Radar#send] = 1
timerset,1,10
GPIO,5,1
on Rules#Timer=1 do
timerset,1,0
GPIO,5,0
Re: prevent a timer restart before expiration
#2 Post by grovkillen » 05 Nov 2018, 22:35
The timers are always disabled one triggered.
on Radar#send do
if [Radar#send]=1
timerset,1,10
GPIO,5,1
Endif
on Rules#Timer=1 do
GPIO,5,0
EndOn
But your code was not correct with closing "endif".
More on rules here: https://www.letscontrolit.com/wiki/inde ... rial_Rules
jopare
#3 Post by jopare » 05 Nov 2018, 22:54
Oh yes, thanks for the hint, i've obviously overlooked this. However, it doesn't change anything on the behaviour.
jopare
#4 Post by jopare » 05 Nov 2018, 23:11
Sorry, i made a mistake. I've forgotten to submit the change. Thanks, everything works as favored.
Domosapiens
#5 Post by Domosapiens » 05 Nov 2018, 23:23
[you replied while i was typing, anyhow....]
Assuming you are using RCWL-0516.
connect RCWL-0516 CDS (Enable) to GPIO 15 (D8).
GPIO 15 (D8) is special for the boot sequence but can be used without pull-up!
On System#Boot do
GPIO,15,1 //Enable RCWL-0516
On Radar#send=1 do
timerset,1,10
GPIO,5,1           //Your relay
GPIO,15,0         //Disable RCWL-0516
On Rules#Timer=1 do
GPIO,5,0
GPIO,15,1        //Re-Enable RCWL-0516
Users browsing this forum: No registered users and 52 guests
