Sooo I've build MEGA locally to implement my own module. THis is the first "Mega" device for me, previously I was using R120. I am using Wemos D1 Mini Pro.
It now dawns on me that my device is "Missing" several plugins, For instance, P016 IR and P035 IRTX simply isn't available in the pulldown when I want to add hardware. I must have forgotten something very silly. Any hint to what?
Plugins "missing"?
Re: Plugins "missing"?
The IR libraries are too big to fit with the normal builds so you have to pick the builds (bin files) named "_IR" to be able to use those plugins.
Ah, got it.grovkillen wrote: ↑16 Nov 2018, 06:20 The IR libraries are too big to fit with the normal builds so you have to pick the builds (bin files) named "_IR" to be able to use those plugins.
So, what is the proper way to combine "IR" with "developent modules"? All _IR_ build options i find are labelled normal_IR_xxx
You will need to compile yourself or ask for a Dev build on GitHub.
Ah, yes, I am building myself. It's just that the IR_build doesnt seem to include my dev module?grovkillen wrote: ↑16 Nov 2018, 17:12 You will need to compile yourself or ask for a Dev build on GitHub.
Edit: Oh wait.. If i change my module to NOT be a dev-module.. it will build with the IR build.. Right? (Doh....)
Should work yes
It did.
Now all i need to figure out is how to send RAW codes properly.. not having much luck there.
Users browsing this forum: No registered users and 61 guests
