Random (pseudoRandom) needed
quajetson
#1 Post by quajetson » 28 Nov 2018, 17:37
Any options to get random value in Rules?
Re: Random (pseudoRandom) needed
#2 Post by grovkillen » 28 Nov 2018, 20:07
Nothing right now. Could you please fill me in on your use case that makes you want a randomized value?
quajetson
#3 Post by quajetson » 01 Dec 2018, 12:49
I need randomly play mp3 on trigger.
quajetson
#4 Post by quajetson » 01 Dec 2018, 12:53
I'm doing speaking head
https://www.youtube.com/watch?v=Y4ojtVn9f58
but playing always hard programmed mp3 sequence is not funny.
#5 Post by grovkillen » 01 Dec 2018, 13:16
Ok, makes sense. Please open a feature request on GitHub.
Suggested command:
Random,<lower>,<upper>
Where <lower> is the lowest randomized value and <upper> it the highest randomized value wanted.
And possibly also able to store to internal value like this:
Random,<lower>,<upper>,<store 1..16>
And you the will be able to use it with %v1% ... %v16%
enesbcs
#6 Post by enesbcs » 01 Dec 2018, 16:26
quajetson wrote: 01 Dec 2018, 12:49 I need randomly play mp3 on trigger.
Is this trigger time based?
If not, i suggest an ugly temporary workaround:
Seconds based fake-random if NTP enabled:
((%syssec%/59)*(upper-lower))+lower
For example the following will give a number between 1 and 17:
((%syssec%/59)*16)+1
The result can be stored in a Dummy variable device with Taskvalueset, and also on the Dummy device page, you can care about digits.
taskvalueset,1,1,(((%syssec%/59)*16)+1)
I think it also can be combined with %rssi%, %sysload% and %sysheap% to be "random"-like but i am lazy to implement. :)
#7 Post by grovkillen » 01 Dec 2018, 19:31
That's a nice try and would perhaps work in some cases :)
quajetson
#8 Post by quajetson » 03 Dec 2018, 10:51
Solved with Dummy device and increment his value with 1 second timer:)
So this is not random but make step needded to play various mp3 or do other actions different way:)
quajetson
#9 Post by quajetson » 03 Dec 2018, 10:54
Thanks enesbcs, Your solution is helpfull too:)
