New ESP Mega builds
the cosmic gate
New ESP Mega builds
#1 Post by the cosmic gate » 03 Dec 2018, 17:28
Start playing around with the latest mega build ( 20181201) but can't find any way to update this firmware to a newer version . Also the <esp ip>/update isn't available anymore ;(
How to update this versions ?
budman1758
Re: New ESP Mega builds
#2 Post by budman1758 » 03 Dec 2018, 18:58
From the "tools" page you scroll down and you will see Load new firmware.
the cosmic gate
#3 Post by the cosmic gate » 03 Dec 2018, 19:05
budman1758 wrote: 03 Dec 2018, 18:58 From the "tools" page you scroll down and you will see Load new firmware.
Nope ;) exact that one is missing :cry:
budman1758
#4 Post by budman1758 » 03 Dec 2018, 19:10
Is that the only thing missing? How about a screenshot of your tools page.
the cosmic gate
#5 Post by the cosmic gate » 03 Dec 2018, 19:19
budman1758 wrote: 03 Dec 2018, 19:10 Is that the only thing missing? How about a screenshot of your tools page.
sure, here you go
budman1758
#6 Post by budman1758 » 03 Dec 2018, 19:38
Interesting..... I had that build on several units and it was there on all of mine. :shock:
Pre-built images or do you self-compile? If self-compile perhaps there is a setting that got changed somewhere?
After that I'm out of ideas..... :idea:
the cosmic gate
#7 Post by the cosmic gate » 03 Dec 2018, 19:45
budman1758 wrote: 03 Dec 2018, 19:38 Interesting..... I had that build on several units and it was there on all of mine. :shock:
I flashed and reflashed the default / pre builds (normal version)
the cosmic gate
#8 Post by the cosmic gate » 08 Dec 2018, 13:21
Nobody else ;) ?
#9 Post by grovkillen » 08 Dec 2018, 17:37
If the firmware button is not there you need to update it with cable.
And what bin file exactly did you use?
themanfrommoon
#10 Post by themanfrommoon » 08 Dec 2018, 17:58
Try another Browser!
Sometimes Browsers have some issues.
#11 Post by TD-er » 10 Dec 2018, 19:23
There is a check to see if an OTA update is possible.
But I guess "disable" the button makes more sense than just removing it ;)
I will add the button and just disable it (including text to explain it) when OTA is not possible.
Simply stated, the space for the sketch should be large enough to hold the new OTA image and the current one.
As a work-around for 1M flash modules we have to 2-step update.
Then you first flash a 2-step-OTA firmware (included in the ZIP) and then the new version.
This new firmware file must then be less than 603(?) kB.
The "Minimal" build should fit, but the last few builds increased that one again, so 2 days ago I patched the build script to only include files in the ZIP when they would fit.
So in the last download you will not see the "minimal" build. (last one working with minimal was 20181204)
Users browsing this forum: No registered users and 149 guests
