LED, LDR and timer using Rules
whatsupskip
#1 Post by whatsupskip » 05 Dec 2018, 05:18
I really thought I would be able to get this to work, but apparently not.
I am not sure if I am supposed to use a virtual switch.
Idea: LDR measures light level. If light level is < 600 turn on LED and start a 5 second timer.
After 5 seconds turn off the LED.
If the light level is > 600 turn off the LED.
Here is what I have tried, but it doesn't work.
on LDR#LightLevel<600 do
     timerSet,1,5
     gpio,0,1
 on Rules#Timer=1 do
     gpio,0,0
 on LDR#LightLevel>600 do
     gpio,0,0
Any help would be appreciated.
Re: LED, LDR and timer using Rules
#2 Post by grovkillen » 05 Dec 2018, 07:04
on LDR#LightLevel do
  if [LDR#LightLevel]<600
     LongPulse,12,1
     GPIO,12,0. //shouldn't be needed but just in case.
If the timer is only used for pulsing the LED pin I'd use LongPulse command instead. GPIO 0 have an internal pull up so you might find it not suitable for what you're trying to do. That is why I use GPIO 12 in the example above.
toffel969
#3 Post by toffel969 » 05 Dec 2018, 09:23
whatsupskip wrote: 05 Dec 2018, 05:18 I really thought I would be able to get this to work, but apparently not.
     timerSet,1,5
     gpio,0,1
 on Rules#Timer=1 do
     gpio,0,0
     gpio,0,0
What is the delay setting on the LDR device ? Does the LED get the light level above 600 ?
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 144 guests
