Read temperature via web command on D1 with SHT30 installed
mattlward
#1 Post by mattlward » 19 Dec 2018, 22:46
I am running several D1's with the latest nightly build and SHT30's onboard. I need send an HTTP command that will read the temperature... How in the world do I do that?
Re: Read temperature via web command on D1 with SHT30 installed
#2 Post by grovkillen » 19 Dec 2018, 23:45
Please explain more.
mattlward
#3 Post by mattlward » 20 Dec 2018, 05:08
I have placed a few of these in network closets for testing at work. The problem is, traditional network monitors do not use MQTT and ESP's do not use SNMP and I need to get the data from the devices. If I can ask the device a question via HTTP that responds with a simple numerical answer, I can directly import that value. I would likely ask the device every minute or so, but not likely an more frequently than that.
I had hoped to use the control?cmd/status for it, but it does not appear to provide more than a question mark for the answer. I could ask for /json, but that is very difficult to break down and out in a probe. Unless I can ask for a very specific variable with an extension to the json command.
#4 Post by grovkillen » 20 Dec 2018, 06:09
You can filter the JSON request but not down to a single value. I guess it could be useful. Please open a new feature request on GitHub.
Domosapiens
#5 Post by Domosapiens » 20 Dec 2018, 10:37
How about this:
make an Event in Rules
Event contains a SendToHTTP with the temperature
Someting like (example to Domoticz):
on testevent do
  SendToHTTP,x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=385&nvalue=0&svalue=[SHT30#Temperature]
Call that Event from outside
http://x.x.x.x/control?cmd=event,testevent
mattlward
#6 Post by mattlward » 20 Dec 2018, 17:46
I can't run software or remote commands on the system that does the monitoring. I really just need the ESP to generate a web page with the numerical temperature.
#7 Post by grovkillen » 20 Dec 2018, 18:16
mattlward wrote:
20 Dec 2018, 17:46
Please, open a feature request on GitHub.
#8 Post by ThomasB » 22 Dec 2018, 04:02
FanOfHue is developing a plugin that might solve your problem.
See viewtopic.php?f=6&t=6098&p=33332
Wiki
#9 Post by Wiki » 22 Dec 2018, 13:04
Just an idea how to solve your task instantly.
Assuming you have a webserver running on your monitoring system just place a small php-script named survey.php on it:
<?php
isset($_GET['value']) ? $value=$_GET['value'] : $value='';
isset($_GET['ID']) ? $ID=$_GET['ID'] : $ID='';
$now = time();
$date = date("d.m.Y", $now);
$time = date("H:i:s", $now);
$page = "Temperature".$ID.".html";
$handle = fopen($page, 'w');
fwrite($handle,"<html>");
fwrite($handle,"<body>");
fwrite($handle,"<p>".$date."</p>");
fwrite($handle,"<p>".$time."</p>");
fwrite($handle,"<p>".$value."</p>");
fwrite($handle,"</body>");
fwrite($handle,"</html>");
fclose($handle);
Define the webserver as Generic HTTP Controller in ESPEasy with Controller Publish "survey.php?value=%value%&ID=%unit%", enable the controller in device settings.
The php script will generate a neat small individual webpage containing date, time and value of each of your different devices named "TemperatureXY.html" (XY=unit no. of the device). On your monitoring system you're now able to call the individual pages using "http://localhost/TemperatureXY.html".
iron
#10 Post by iron » 26 Dec 2018, 10:54
Do not forget the custom web pages.
Just upload an .htm file (http://ip_of_your_device/upload) that returns just the value you want and then call that file within your call url e.g. :
http://<ip of you device/return1.htm
-D
-D
Wiki
#11 Post by Wiki » 26 Dec 2018, 14:21
iron wrote:
26 Dec 2018, 10:54
-D
Interesting. I didn't read about this possibility anything. Do you have some links for documentation?
iron
#12 Post by iron » 26 Dec 2018, 15:32
Wiki wrote:
26 Dec 2018, 14:21
iron wrote:
26 Dec 2018, 10:54
-D
https://www.letscontrolit.com/wiki/inde ... _Dashboard
but all you have to do is upload your own .htm file that posts the value you wish as a response. and then call that url. That's all.
If you extend your file as .esp the system will be doing some parsing as in the example in the link.
if you extend it as .htm there will be no parsing.
Whichever works the best for you.
-D
-D
Wiki
#13 Post by Wiki » 26 Dec 2018, 18:56
Wow, that's cute.
Thank you for this information. I think this is exactly what mattlward was looking for - and at least, me, too.
Users browsing this forum: Google [Bot] and 20 guests
