ESP8266 rapport erreur Plugin _P127_Teleinfo
T3rorX
#1 Post by T3rorX » 03 Jan 2019, 14:28
Bonjour,
Je réfléchis à mettre en place un ESP8266 dans mon local compteur ERDF, mais impossible de compiler avec Atom.
Voici les erreurs
H:/GitHub/ESPEasy/src/_P127_Teleinfo.ino: In function 'boolean Plugin_127(byte, EventStruct*, String&)':
H:/GitHub/ESPEasy/src/_P127_Teleinfo.ino:189:49: error: incompatible types in assignment of 'int' to 'unsigned int [32]'
H:/GitHub/ESPEasy/src/_P127_Teleinfo.ino:245:14: warning: unused variable 'log' [-Wunused-variable]
sprintf_P(log, PSTR("%s%s using port %u"), "HTTP : connecting to ", host, port);
H:/GitHub/ESPEasy/src/_P127_Teleinfo.ino:45:15: warning: unused variable 'connectionState' [-Wunused-variable]
H:/GitHub/ESPEasy/src/_P127_Teleinfo.ino: In function 'boolean P127_sendtoHTTP(String, int, String)':
H:/GitHub/ESPEasy/src/_P127_Teleinfo.ino:585:1: warning: control reaches end of non-void function [-Wreturn-type]
*** [.pioenvs\esp32test_1M8_partition\src\ESPEasy.ino.cpp.o] Error 1
_P127_teleinfo.ino Pris sur https://github.com/letscontrolit/ESPEas ... Playground
//#################################### Plugin 127: Teleinfo #############################################
//#################################### This plugin transmits data of energy counter to HTTP server  #####
//#################################### Compatible with jeedom plugin Teleinfo                       #####
#define PLUGIN_127
#define PLUGIN_ID_127         127
#define PLUGIN_NAME_127       "Teleinfo"
#define P127_BUFFER_SIZE 128
boolean Plugin_127_init = false;
int P127_CYCLE = 0;
String P127_SendData = "";
String P127_URL = "";
int P127_PORT = 80;
String P127_HOST = "";
boolean Plugin_127(byte function, struct EventStruct *event, String& string)
  boolean success = false;
  static byte connectionState = 0;
  switch (function)
    case PLUGIN_DEVICE_ADD:
        Device[++deviceCount].Number = PLUGIN_ID_127;
        Device[deviceCount].SendDataOption = false;
        Device[deviceCount].TimerOption = false;
        Device[deviceCount].Custom = true;
        Device[deviceCount].ValueCount = 0;
    case PLUGIN_GET_DEVICENAME:
        string = F(PLUGIN_NAME_127);
    case PLUGIN_WEBFORM_LOAD:
        char deviceTemplate[2][128];
        LoadCustomTaskSettings(event->TaskIndex, (byte*)&deviceTemplate, sizeof(deviceTemplate));
        string += F("<TR><TD>Host:<TD><input type='text' size='64' maxlength='128' name='Plugin_127_host' value='");
        string += deviceTemplate[0];
        string += F("'>");
        char tmpString[128];
        sprintf_P(tmpString, PSTR("<TR><TD>Port:<TD><input type='text' name='Plugin_127_port' value='%u'>"), Settings.TaskDevicePluginConfig[event->TaskIndex][0]);
        string += tmpString;
        string += F("<TR><TD>Start url:<TD><input type='text' size='64' maxlength='128' name='Plugin_127_url' value='");
        string += deviceTemplate[1];
        string += F("'>");
        success = true;
    case PLUGIN_WEBFORM_SAVE:
        String plugin1 = WebServer.arg("Plugin_127_port");
        Settings.TaskDevicePluginConfig[event->TaskIndex][0] = plugin1.toInt();
        char argc[25];
        String arg = F("Plugin_127_host");
        arg.toCharArray(argc, 25);
        String tmpString = WebServer.arg(argc);
        strncpy(deviceTemplate[0], tmpString.c_str(), sizeof(deviceTemplate[0]));
        arg = F("Plugin_127_url");
        strncpy(deviceTemplate[1], tmpString.c_str(), sizeof(deviceTemplate[1]));
        Settings.TaskDeviceID[event->TaskIndex] = 1; // temp fix, needs a dummy value
        success = true;
    case PLUGIN_INIT: // ok
        P127_HOST = String(deviceTemplate[0]);
        P127_PORT = int(Settings.TaskDevicePluginConfig[event->TaskIndex][0]);
        P127_URL = String(deviceTemplate[1]);
        Serial.begin(1200, SERIAL_7E1); //Liaison série avec les paramètres
        Plugin_127_init = true;
        success = true;
    case PLUGIN_SERIAL_IN:
        uint8_t serial_buf[P127_BUFFER_SIZE];
        int RXWait = 10;
        int timeOut = RXWait;
        size_t bytes_read = 0;
        char log[40];
        while (timeOut > 0)
          while (Serial.available()) {
            if (bytes_read < P127_BUFFER_SIZE) {
              serial_buf[bytes_read] = Serial.read();
              bytes_read++;
            else {
              Serial.read();  // when the buffer is full, just read remaining input, but do not store...
            timeOut = RXWait; // if serial received, reset timeout counter
          delay(1);
          timeOut--;
        if (bytes_read == P127_BUFFER_SIZE)  // if we have a full buffer, drop the last position to stuff with string end marker
          while (Serial.available()) { // read possible remaining data to avoid sending rubbish...
            Serial.read();
          bytes_read--;
          // and log buffer full situation
          // strcpy_P(log, PSTR("Teleinfo: serial buffer full!"));
          // addLog(LOG_LEVEL_ERROR, log);
        serial_buf[bytes_read] = 0; // before logging as a char array, zero terminate the last position to be safe.
        //	char log[P127_BUFFER_SIZE + 40];
        //	sprintf_P(log, PSTR("Ser2N: S>: %s"), (char*)serial_buf);
        //	addLog(LOG_LEVEL_DEBUG, log);
        // We can also use the rules engine for local control!
        String message = (char*)serial_buf;
        int NewLinePos = message.indexOf("\r\n");
        if (NewLinePos > 0) {
          message = message.substring(0, NewLinePos);
        String eventString = "";
        // message.replace("\r", "");
        if (message.length() > 5) {
          int indexValue = message.indexOf(" ");
          String nameValue = message.substring(1, indexValue);
          String value = message.substring(indexValue + 1, message.length() - 3);
          String checksum = message.substring(message.length() - 2);
          //  UserVar[event->BaseVarIndex] = value.toInt();
          if (P127_CYCLE == 0) {
            if (P127_checksum(nameValue, value, checksum)) {
              eventString = F("Teleinfo#");
              eventString += nameValue;
              eventString += F("=");
              eventString += value;
              P127_SendData += nameValue + "=" + value + "&";
          if (nameValue == "ADCO") {
            if (P127_CYCLE < 8) {
              P127_CYCLE++;
            } else {
              if (  P127_checksum(nameValue, value, checksum) ) {
                eventString = F("Teleinfo#SendData");
                P127_CYCLE = 0;
                P127_sendtoHTTP(P127_HOST, P127_PORT, P127_URL + P127_SendData);
                P127_SendData = "";
          if (eventString.length() > 0) {
            rulesProcessing(eventString);
        success = true;
  return success;
boolean P127_checksum(String valuename, String value, String checksum) {
  String data = "";
  int i;
  char sum = 0;
  char sumchar;
  sumchar = checksum.charAt(0);
  data = valuename + " " + value;
  for (i = 0; i < data.length(); i++) {
    sum = sum + data.charAt(i);
  sum = (sum & 0x3F) + 0x20;
  if (sum == sumchar) {
    return true;
  } else {
    return false;
boolean P127_sendtoHTTP(String hostname, int port, String url) {
  char log[80];
  char host[128];
  hostname.toCharArray(host, 128);
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  if (!client.connect(host, port))
    connectionFailures++;
    strcpy_P(log, PSTR("HTTP : connection failed"));
    return false;
  statusLED(true);
  if (connectionFailures)
    connectionFailures--;
  url.toCharArray(log, 80);
  addLog(LOG_LEVEL_DEBUG_MORE, log);
  String hostName = host;
  // This will send the request to the server
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  unsigned long timer = millis() + 200;
  while (!client.available() && millis() < timer)
    delay(1);
  // Read all the lines of the reply from server and print them to Serial
  while (client.available()) {
    String line = client.readStringUntil('\n');
    line.toCharArray(log, 80);
    if (line.substring(0, 15) == "HTTP/1.1 200 OK")
      strcpy_P(log, PSTR("HTTP : Succes!"));
      success = true;
    delay(1);
  strcpy_P(log, PSTR("HTTP : closing connection"));
  client.flush();
  client.stop();
Merci de votre aide.
gmella
Re: ESP8266 rapport erreur Plugin _P127_Teleinfo
#2 Post by gmella » 26 Mar 2020, 18:57
Bonjour,
Je teste depuis quelques semaines mon compteur Linky avec le plugin que tu cites sur lequel j'ai fait pas mal de modifications. C'est stable en remontant même les infos toutes les 20s à mon controlleur domoticz.
Je n'ai pas encore fait de pull request et j'hesite à faire un nouveau plugin. Mais je vais essayer de contribuer un peu plus dans ce super projet qu'est EspEasy.
En attendant voila le code si cela peut servir et relancer les échanges:
https://github.com/gmella/ESPEasyPlugin ... leinfo.ino
Attention comme mentionné c'est en mode STANDARD donc a completer pour supporter les deux modes...
Thanks a lot for ESPEasy ! I enjoy and use it more and more.
Merci aussi à Charles Hallard pour sa lib et autres infos.
Guillaume
