While it IS possible to set the IP address via rules, there doesn't seem to be a way to set the gateway. I have two locations I want to use a device AND I want the device to have a particular last section of the IP. For example, for the primary SSID I want the address to be 10.0.0.19 on the fallback SSID I want it to be 192.168.1.19 - I have tried adding a rule that looks at the SSID and then assigns the IP I want, but if I reboot, I get the IP that the router deside to hand to me. Same thing if I use a serial monitor and set the IP then disconnect the wifi, I still end up with the IP assigned by the router.
Bottom line if if I connect to the primary SSID I want one IP address, if I connect to the fallback SSID I want another IP, both ending it an assigned octal (?I think that is the term)
Anyone have nay ideas?
How to set ESP GW (gateway) via commands
Re: How to set ESP GW (gateway) via commands
Gateway,<ip>
Users browsing this forum: Bing [Bot] and 49 guests
