store a variable persistent in config section
riker1
#1 Post by riker1 » 06 Jan 2019, 11:10
I am wondering if I can store a variable persistent in a flash part maybe config sections ?
thanks T
Re: store a variable persistent in config section
#2 Post by grovkillen » 06 Jan 2019, 11:26
Yes and no. Nothing which is set dynamically will survive a boot. BUT you can use a MQTT broker and MQTT import to fetch the value from there (if you have the retained setting checked).
But we're discussing a external flash (EEPROM) which could be used.
riker1
#3 Post by riker1 » 06 Jan 2019, 12:09
ok thanks
obod0002c
#4 Post by obod0002c » 12 Aug 2019, 15:16
grovkillen wrote:
06 Jan 2019, 11:26
I'd like to re-activate this question: for quite a few of my ESP's I programmed myself, I had the necessity to store values that would survive even long periods of no power.
Either because I do not want to enable WiFi or simply because I can't.
Yes, I know, memory cells are wearing out, like all hardware and us human beings, too.
But a change from time to time shouldn't really harm the devices.
Maybe there's a chance to get this feature - or is it already available - and I have browsed only those messages were it wasn't?
As ESP Easy already uses persistent storage, it shouldn't be a big effort ... credentials, drivers, rules, all seem to be pretty persistent. Maybe a small change in the device's section or a few new system variables would do?
#5 Post by grovkillen » 12 Aug 2019, 17:28
We're discussing implementing external EEPROM as well as a command to store to flash.
