Possible to use previoustate in rules ?
DaveS
#1 Post by DaveS » 10 Jan 2019, 17:48
Hi Chaps,
ESPeasy is monitoring my rain water tanks and controlling 2 latching solenoid valves - one on tank supply to house and another on the council water feed.
I use the rules below but the solenoids are pulsed every few seconds even if their state does not need to change.
On WaterLevel#Litres>10 do
gpio,13,1   //status LED
gpio,14,0  // status LED
Pulse,4,1,500  // pulse solenoid valve 1
On WaterLevel#Litres<10 do
gpio,14,1
gpio,13,0
Pulse,5,1,500  // pulse solenoid valve 2
Is there a "previousstate" type command that can be used in rules to disable the rule unless the solenoid needs to change state ?
Cheers
iron
Re: Possible to use previoustate in rules ?
#2 Post by iron » 10 Jan 2019, 19:19
gpiotoggle,<pin#>
will toggle the state of the pin if this is what you are asking ?
-D
-D
DaveS
#3 Post by DaveS » 10 Jan 2019, 19:26
Thanks for the reply,however I am trying to configure the rules so they trigger once only when the waterlevel#litres>10 and again when waterlevel#litres<10 condition is met,not pulse the solenoid control IO's over and over.
iron
#4 Post by iron » 10 Jan 2019, 19:45
How about ?
On WaterLevel#Litres>10 and gpio#13=0 do
Not even sure if you can you use AND/OR in the event, but you can try and let us know.
If not :
If gpio#13=0
if gpio#13=1
gpio,14,1
gpio,13,0
-D
-D
DaveS
#5 Post by DaveS » 11 Jan 2019, 19:59
Thanks iron for the idea,rule below working perfectly, I was thinking of setting up a dummy item but this is a simpler method ..
On WaterLevel#Litres>220 do
if [TankSolenoid#State]=0
gpio,13,1
gpio,14,0
Pulse,4,1,500
On WaterLevel#Litres<220 do
if [MuniSolenoid#State]=0
gpio,14,1
gpio,13,0
Pulse,5,1,500
Cheers
Users browsing this forum: Bing [Bot] and 116 guests
