Strobe light controlled by a rule possible?
P406
#1 Post by P406 » 11 Jan 2019, 19:49
Hello folks,
first of all, let me thank you for this awesome work!! :)
ESPeasy is one of the best things for my smarthome !
I need a little help regarding the following:
I would like to create a strobe light (something like 500ms GPIO HIGH, 500ms GPIO LOW) and use the timer inside ESPeasy...
All I want to to is send a command like IPADRESS/?cmd=strobe/1 and strobe/0 .
Anybody an idea how to get this to work?
Kind regards,
P406
iron
Re: Strobe light controlled by a rule possible?
#2 Post by iron » 11 Jan 2019, 20:47
the best practice is to send an "event" to the device
http://<espeasyip>/control?cmd=event
Then in the Rules catch the event :
On event do
Your condition here
More in the Rules :
https://espeasy.readthedocs.io/en/lates ... Rules.html
-D
-D
P406
#3 Post by P406 » 12 Jan 2019, 13:16
Hi iron,
I tried the example from "best practice", but the led is just flashing 1 time and is not repeated in a loop (like I understood the example?) :
 //start the warning signal when we receive a start_warning event:
 On start_warning do
   timerSet,1,2
 //stop the warning signal when we receive a stop_warning event:
 On stop_warning do
   timerSet,1,0
 //create an actual warning signal, every time timer 1 expires:
 On Rules#Timer=1 do
   //repeat after 2 seconds
   timerSet,1,2
   //pulse some led on pin 15 shortly
   Pulse,15,1,100
Kind regards,
P406
iron
#4 Post by iron » 12 Jan 2019, 14:44
gpio 15 is pulled to GND and generally recommended for input only
https://espeasy.readthedocs.io/en/lates ... light=gpio
Try another gpio (preferably 5,6,7)
-D
-D
P406
#5 Post by P406 » 13 Jan 2019, 16:31
Okay, but why should this have an impact on the rule or timer...?
EDIT: Whats GPIO 6 and 7 in ESPeasy....?
GPIO5 is SCL in my case... Okay but I can change this.
Kind regards,
P406
P406
#6 Post by P406 » 16 Jan 2019, 17:43
Nobody? Which outputs are recommended for PWM usage (LEDs)?
Kind regards,
P406
#7 Post by grovkillen » 16 Jan 2019, 17:54
GPIO 12 13 14 are good pins for PWM.
