Hello folks,
first of all, let me thank you for this awesome work!!
ESPeasy is one of the best things for my smarthome !
I need a little help regarding the following:
I would like to create a strobe light (something like 500ms GPIO HIGH, 500ms GPIO LOW) and use the timer inside ESPeasy...
All I want to to is send a command like IPADRESS/?cmd=strobe/1 and strobe/0 .
Anybody an idea how to get this to work?
Kind regards,
P406
Strobe light controlled by a rule possible?
Re: Strobe light controlled by a rule possible?
the best practice is to send an "event" to the device
http://<espeasyip>/control?cmd=event
Then in the Rules catch the event :
On event do
Your condition here
More in the Rules :
https://espeasy.readthedocs.io/en/lates ... Rules.html
-D
On event do
Your condition here
More in the Rules :
-D
-D
Hi iron,
I tried the example from "best practice", but the led is just flashing 1 time and is not repeated in a loop (like I understood the example?) :
Kind regards,
P406
//start the warning signal when we receive a start_warning event:
On start_warning do
timerSet,1,2
//stop the warning signal when we receive a stop_warning event:
On stop_warning do
timerSet,1,0
//create an actual warning signal, every time timer 1 expires:
On Rules#Timer=1 do
//repeat after 2 seconds
timerSet,1,2
//pulse some led on pin 15 shortly
Pulse,15,1,100
P406
gpio 15 is pulled to GND and generally recommended for input only
https://espeasy.readthedocs.io/en/lates ... light=gpio
Try another gpio (preferably 5,6,7)
-D
-D
-D
Okay, but why should this have an impact on the rule or timer...?
EDIT: Whats GPIO 6 and 7 in ESPeasy....?
GPIO5 is SCL in my case... Okay but I can change this.
Kind regards,
P406
Kind regards,
P406
Nobody? Which outputs are recommended for PWM usage (LEDs)?
Kind regards,
P406
Kind regards,
P406
GPIO 12 13 14 are good pins for PWM.
Users browsing this forum: No registered users and 114 guests
