Comand:
http://192.168.1.6/control?cmd=GPIO,12,1 Turn on my relay but...\
http://192.168.1.6/control?cmd=GPIO,12,0 Don't turn it off :/
Can someone help me to make it work ? I use mqtt and http just for testing. Relay turn off after power then I can turn it on again and can't turn it off :/
relay go on but after gpio12.0 it will stay on help plz
Re: relay go on but after gpio12.0 it will stay on help plz
Which hardware ?
And which version of ESPeasy ?
I think, it must works.
What response of your ESP in browser after sending this commands?
mega-20190116And which version of ESPeasy ?
http://192.168.1.9/control?cmd=GPIO,12,1What response of your ESP in browser after sending this commands?
"log": "GPIO 12 Set to 1",
"plugin": 1,
"pin": 12,
"mode": "output",
"state": 1
http://192.168.1.9/control?cmd=GPIO,12,0
"log": "GPIO 12 Set to 0",
"plugin": 1,
"pin": 12,
"mode": "output",
"state": 1
after I use command again I got
"plugin": 1,
"pin": 12,
"mode": "output",
"state": 0
state change but led diode on relay stay on :/
Look here:
http://www.wholesalebuying.com/product/ ... ino-214386
"Relay control interface by single chip IO.
Low level suction close, high level release."
http://irishelectronics.ie/epages/95001 ... /SRD-05VDC
"Description:
SWITCH ON GROUND"
So it is not possible, that you switch relay on with gpio,12,1
You give us wrong information.
Relay is switched on by log0 and off by log1.
Maybe 3V log 1 from ESP is not enough for 5V relay logic - so ti is not switched off.
Disconnect relay and measure log levels directly on gpio-12
"Description:
SWITCH ON GROUND"
Look how this boy connected one from four relays on board from the same manufacturer - YWROBOT
Through transistor ....
https://www.instructables.com/id/ESP826 ... martphone/
https://cdn.instructables.com/ORIG/F9Z/ ... 8KRC7U.pdf
Users browsing this forum: Ahrefs [Bot] and 111 guests
