New rules engine
Wiki
New rules engine
#1 Post by Wiki » 28 Jan 2019, 12:59
I am trying to get the new rules engine to run.
- Adding new event named rule#1
- putting inside a rule, e.g.
on Clock#Time=All,**:*0 do
Publish domoticz/in,{"idx":53,"nvalue":0,"svalue":"%uptime%"}
- submitting, file "rules/rule/1.txt" is created
- nothing happens, I can see. edit and delete the rule, but the rule itself is never running
Tried with ESP_Easy_mega-20190108_normal_core_241_ESP8266_4096.bin
Re: New rules engine
#2 Post by grovkillen » 28 Jan 2019, 19:43
The name of the file must be the name of the event. So in your case that will only trigger when the event "rules#1" happens.
Naming it "Clock#Time" and it will be triggered every minute.
Wiki
#3 Post by Wiki » 29 Jan 2019, 01:04
Thank you, now the example works, the naming convention makes sence in this case.
But if I define my own event named "startwatering" to trigger it by
http://<ip>/control?cmd=event,startwatering=1
how do I have to name the rule that it is saved without the formats error message and is running afterwards correctly?
#4 Post by grovkillen » 29 Jan 2019, 05:38
Yep, it's a work in progress... So the event need to be of the abc#def syntax. You can try to change the event to start#watering perhaps?
Wiki
#5 Post by Wiki » 29 Jan 2019, 11:02
OK, I'll try and will report.
Users browsing this forum: Bing [Bot] and 9 guests
