Serial port
dynamicdave
Serial port
#1 Post by dynamicdave » 06 Feb 2019, 08:16
I'm trying to use the serial port on a Wemos D1 Mini.
The two problems I have are..
(1) Extracting the data from the received message
(2) Trying to find a way of sending data/variable from the Wemos via the serial port
Note:
I'm using the very latest version of ESP Easy mega 20190202 release.
Any help or guidance would be greatly appreciated.
Kind regards from David.
kimot
Re: Serial port
#2 Post by kimot » 06 Feb 2019, 18:31
(1)
I think data extraction will be difficult.
Is not it better to send data in a correct format?:
viewtopic.php?t=4884
(2)
serialsend
Look at post from "mikeluyten" here:
https://github.com/letscontrolit/ESPEasy/issues/539
dynamicdave
Re: Serial port
#3 Post by dynamicdave » 06 Feb 2019, 21:03
Thanks for all your help.
I can now send information/data from the WeMos to my terminal (app running on a mobile phone) using rules.
on !Serial#* do
publish david,%eventvalue%
serialsend %eventvalue%
I can also set a dummy variable using this http command.
http://192.168.1.90/control?cmd=TaskValueSet,12,1,22
What I can't work out is how to send a command-string from my terminal (mobile phone) to the Wemos.
I've tried sending the text string... TaskValueSet,12,1,22 (and all sorts of variations of this) but nothing happens in the dummy variable.
Is there something I should prefix the string with??
PS: Which version of ESP Easy are you using?
Cino2424
Re: Serial port
#4 Post by Cino2424 » 28 Feb 2019, 19:16
I do it in this way
void tempread() {
float h = dht.readHumidity();
float t = dht.readTemperature();
char temp[] = "TaskValueSet,1,1,";
char hum[] = "TaskValueSet,1,2,";
Serial.print(temp);
Serial.println(t);
Serial.print(hum);
Serial.println(h);
Users browsing this forum: Bing [Bot] and 23 guests
