LCD - clear before write
I have a module with R63 and a LCD2004. When I write something on the display, existing text is not cleared
For instance, upon startup the first line says "ESPeasy" - if I write "test" on line 1, the display will read "testasy", and if I have a temperature reading saying "T: 22.44 C" and the next temperature is only one digit, it will read "T: 22.2 CC"
I think we either need to clear a line before writing a new, or pad all lines with spaces to always write 16/20 characters (depending on display size)
And a feature request: I know we have %systime% - could we also have %uptime% (I understand the disabling NTP changes systime to uptime, but I would like to keep NTP enabled)
- Jan
- Jan
Jan Chrillesen, Denmark
Re: LCD - clear before write
The same effect also applies to the OLED display.
In the version R59 the error was already present.
I second the request, which is discussed in another thread: http://www.esp8266.nu/forum/viewtopic.p ... time#p3013chrille wrote: And a feature request: I know we have %systime% - could we also have %uptime% (I understand the disabling NTP changes systime to uptime, but I would like to keep NTP enabled)
- Jan
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
Next build will use padding to solve this (both LCD and OLED)chrille wrote:I think we either need to clear a line before writing a new, or pad all lines with spaces to always write 16/20 characters (depending on display size)
- Jan
Next build will have %uptime% as system variable.
Great news. And is there any way of updating Domoticz with uptime as the value of a sensor?Martinus wrote:Next build will have %uptime% as system variable.
Maybe using thie Event Action plugin we have discussed before, say one time during the day/night? This way, we would be able to say, if the module is stable or not?
This should probably be moved to a new thread, but it would surely be great to have virtual "sensors" to report stuff likemkotek wrote:Maybe using thie Event Action plugin we have discussed before, say one time during the day/night? This way, we would be able to say, if the module is stable or not?
- uptime
- memory usage
- wifi RSSI
- mac address
- IP address
- software version
Especially memory usage and RSSI I find useful
- Jan
I do not know your usage scenario, but in my case, ESP is just passing information from a fixed location to controller. In such case, memory uisage and RSSI stays the same (withing boundaries), so it is not needed, but your mileage may vary and I guess, this is not an issue to add additional variables, once the whole framweork for publishing such parameters would be in place.chrille wrote:This should probably be moved to a new thread, but it would surely be great to have virtual "sensors" to report stuff likemkotek wrote:Maybe using thie Event Action plugin we have discussed before, say one time during the day/night? This way, we would be able to say, if the module is stable or not?
- uptime
- memory usage
- wifi RSSI
- mac address
- IP address
- software version
- Jan
Hi Martinus,Martinus wrote:Next build will use padding to solve this (both LCD and OLED)
Thank you very much for fixing/adding this
- Jan
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 151 guests
