Generic - Pulse counter - RISING FALLING CHANGE no difference
Sektflasche
#1 Post by Sektflasche » 25 Feb 2019, 14:09
hi,
I use "Generic - Pulse counter" device with a TCRT5000 sensor to read my water-counter.
Everything is fine but the counter register every round as two impulses. It make no difference if the "mode type" is "RISING", "FALLING" or "CHANGE". It creates always two impulses.
Every ideas?
ps. It's not a good solution to divide the value by 2 because, when the measuring wheel will stop for a while in status hi, then my result will by not right.
Thank you
Sektflasche
Re: Generic - Pulse counter - RISING FALLING CHANGE no difference
#2 Post by Sektflasche » 28 Feb 2019, 10:36
I found this information viewtopic.php?f=6&t=1143&p=5429&hilit=TCRT5000#p6407. It looks like the issue is still open: https://github.com/letscontrolit/ESPEasy/issues/2366
https://github.com/letscontrolit/ESPEas ... _Pulse.ino
35        Device[++deviceCount].Number = PLUGIN_ID_003;
36        Device[deviceCount].Type = DEVICE_TYPE_SINGLE;
37        Device[deviceCount].VType = SENSOR_TYPE_SINGLE;
Users browsing this forum: Bing [Bot], Google [Bot] and 24 guests
