(solved) webinterface password
riker1
#1 Post by riker1 » 29 Mar 2019, 14:46
I did set a admin password while flashing
but what is the user when logging into the webinterface?
How do I forward user and password using http requests?
did not find it in the wiki?
Thanks T
riker1
Re: webinterface password
#2 Post by riker1 » 29 Mar 2019, 14:59
I tried to change
name and password
but can not use those in the weblogin?
what am I doing wrong?
Thanks T
#3 Post by ThomasB » 29 Mar 2019, 19:14
The value for ADMIN USERNAME is: admin
The name is hard coded in ESPEasy-Globals.h. It requires a re-compile to change (edit DEFAULT_ADMIN_USERNAME).
riker1
#4 Post by riker1 » 29 Mar 2019, 19:55
Hi Thomas,
ok thanks
so command name
does not do anything
there is only on user : admin
no other users possible, right?
T
#5 Post by ThomasB » 29 Mar 2019, 20:07
The command name changes the UNIT's name (Device ID). To put it another way, it is the same as visiting the webui and changing the Unit Name found at the top of the Config page.
Unlike the Admin Name, you can easily change the the Unit Name.
riker1
#6 Post by riker1 » 30 Mar 2019, 09:49
ah ok understood
thx
Users browsing this forum: Bing [Bot] and 9 guests
