ESPEasy WiFi reconnect Rules
Rob Muller
#1 Post by Rob Muller » 08 Apr 2019, 13:11
Friends,
After a recent router failure i experienced that ESPEasy would not reconnect to WiFi on its own. A device reboot was required.
All my devices run a stable version of ESPEasy Mega-......
I could not find a script to monitor WiFi without use of plugins not available in the basic stable version, and i try to stay off the {b}leeding edge...
So i cobbled this together, i tested this on many versions and it worked for all Mega....
on System#Boot do
    Let,1,0                              // set user variable to initial state of 0
EndOn
on Wifi#Disconnected do              	 // if no wifi, wait 3 minutes
  if [VAR#1]=0
    timerSet,1,180
    Let,1,1                              // set user variable 1 to 1 to prevent re-set of var1 on each event.
on Wifi#Connected do     	 	 // if wifi returns, cancel reboot
  timerSet,1,0                    	 // cancel timer
  Let,1,0                                // set user variable 1 to 0
On Rules#Timer=1 do                    	 // if still no Wifi, reboot
  reboot
I hope others will find a use for this.
If you have improvements or a beter idea, share please
Regards,
Rob
Thanks for reading,
regards,
Rob
riker1
Re: ESPEasy WiFi reconnect Rules
#2 Post by riker1 » 08 Apr 2019, 14:25
thanks
Was wondering is a
wificonnect
would solve it ,
doing a reboot is more save?
Rob Muller
#3 Post by Rob Muller » 08 Apr 2019, 19:17
Riker1,
I tried that and could not get it to work reliably, but a reboot worked 100% of the time.
maybe a reboot clears something in memory that prevents re-connection.
I tested using the following method, as i have only one wifi network and cannot switch that off if i want to live (Wife!!)
Testing method:
connect to iPhone personal hotspot
open serial connection
switch off personal hotspot and observe reconnect in serial console
thanks for your reaction
Rob
Thanks for reading,
regards,
Rob
riker1
#4 Post by riker1 » 09 Apr 2019, 07:53
thanks Rob
1CM69
#5 Post by 1CM69 » 09 Apr 2019, 13:29
Rob Muller wrote:
08 Apr 2019, 13:11
Friends,
on System#Boot do
EndOn
  if [VAR#1]=0
    timerSet,1,180
  reboot
Regards,
Rob
Nice, thanks
hoeby
#6 Post by hoeby » 04 Aug 2019, 21:21
Would like to use the script, but have some question about it
The script uses
VAR#1
Do i need to make a dummy device (or something else) to store the value.
Or is VAR a default function in espeasy?
#7 Post by ThomasB » 04 Aug 2019, 22:05
VARs (VAR#1 - VAR#16, alias %v1% - %v16%) are Custom Variables that are separate from those used in the dummy plugin. They are built-in/default, so a plugin is not needed to use them. Some details:
viewtopic.php?t=6288
Useful Things to know:
- Unlike Dummy plugin defined variables, the %v% variables are lost (reset to zero) on a warm reboot. So choose a Dummy for values that must survive ESPEz's pandemic random reboots.
- For debugging, you can see the values of all the %v% on the Tools=>SystemVariables page.
mpolet
#8 Post by mpolet » 01 Dec 2019, 08:51
Had exactly the same; the wemos itself was alive for 8 days but not connecting to my AP. The 'configesp' AP was visible from my laptop though. After rebooting it (via that configesp) it was connecting to my AP again.
I now implemented your script in it, see how it will perform now.
#9 Post by TD-er » 01 Dec 2019, 13:19
Maybe also use a more recent build.
A few weeks ago I addressed some logic issues in when to reconnect, when to start the AP etc.
Users browsing this forum: Bing [Bot] and 21 guests
