Why does this rule stop working ?
DaveS
#1 Post by DaveS » 11 Apr 2019, 19:23
Hi Chaps,
I am using version mega-20190305
This is a home brew beer fermentation chamber controller.
I need a 15 minute timeout after the fridge compressor turns off before it gets turned on again.
The rules below work once after boot when the temp rises above 18 degrees but once the temperature drops below 18 degrees the fridge turns off and never turns on again when temperature rises.
On System#Boot do     //Not sure if this needed ? - Used to set timer expired flag 10 seconds after boot
timerSet,1,10
On Fermenter_Temp#Fermenter_Temperature<17 do     // turn on heater
gpio,12,0
gpio,14,1
Publish /FermoStat/gpio/14,1
On Fermenter_Temp#Fermenter_Temperature do
if [Fermenter_Temp#Fermenter_Temperature]>18 and [Rules#Timer]=1      //=1 checks if timer has expired then turn on fridge
gpio,14,0
gpio,12,1
Publish /FermoStat/gpio/12,1
On Fermenter_Temp#Fermenter_Temperature>17 do     // turn off heater
gpio,14,0
Publish /FermoStat/gpio/14,0
On Fermenter_Temp#Fermenter_Temperature<18 do     // turn off fridge
gpio,12,0
Publish /FermoStat/gpio/12,0
timerSet,1,900                     //set timer 1 for 900 seconds (15 minutes)
Any idea why rule stops working or is there a better way to implement this ?
Re: Why does this rule stop working ?
#2 Post by ThomasB » 11 Apr 2019, 21:54
Hmm. I don't believe a timer event is designed to be used in a conditional expression, as seen in this statement:
Instead, have the Timer set a variable. This variable will be used in your conditional rule to replace the "[Rules#Timer]=1." The rules will need to also restart the timer and clear the variable.
Also, to streamline the code you could have just one "On Fermenter_Temp#Fermenter_Temperature" event and put all the temperature related conditions within it. Just food for thought.
DaveS
#3 Post by DaveS » 23 Apr 2019, 19:25
Will have the timer set a variable,
Thanks for the info.
Regards Dave
