(solved - user error) sendto sendhttp no eventvalue data send
riker1
#1 Post by riker1 » 17 Apr 2019, 21:11
I am unsing sendto
and sendhttp
but the eventvalues are not send.
  sendTo 149,event,disp_kt=[esp01_178_Temp#esp01_178_Temp]
   SendToHTTP 192.168.0.149,/control?cmd=event,http_kt=99
tried it wix fix value and variable from device.
what am I doing wrong
log shows:
197048: ACT  : sendTo 149,event,disp_kt=
197060: Command: sendto
197127: ACT  : SendToHTTP 192.168.0.149,/control?cmd=event,http_kt=99
197140: Command: sendtohttp
46081: EVENT: esp01_178_Temp#esp01_178_V_Temp=-28.81
46112: ACT  : timerset,2,2
46124: Command: timerset
46145: ACT  : sendTo 149,event,var_kt=
46157: Command: sendto
46243: ACT  : Publish esp01_23_115_KT/Event-device-upd,http_kt= um -192.168.10.115-2019-04-17 21:10:31
46256: Command: publish
Thanks T
schnurzel59
Re: sendto sendhttp no eventvalue data send
#2 Post by schnurzel59 » 28 Apr 2019, 11:54
Your information is a bit short. If you do not have a solution, you should describe a few more things.
"ACT: sendTo 149, event, disp_kt =" shows that your "[esp01_178_Temp # esp01_178_Temp]" must be incorrect.
Otherwise there would have to be a value after "... disp_kt =".
Why "SendToHTTP"?
"SendTo 1,event,http_kt=99" is fully functional.
on sendetest do
taskvalueset,2,1,86345 //Device 2.1 Name: "test" value: "State"
sendTo 1,event,disp_kt,[test#State]
SendTo 1,event,http_kt=999
7512176: ACT : taskvalueset,2,1,86345
7512186: Command: taskvalueset
7512196: ACT : sendTo 1,event,disp_kt,86345
7512208: Command: sendto
7512275: ACT : SendTo 1,event,http_kt=999
7512285: Command: sendto
Result:Image
Greetings Martin
Oh God, my English is horrible.
riker1
#3 Post by riker1 » 29 Apr 2019, 12:11
Hi Martin,
thanks
I found an issue - as you said - in the device variable.
so mainly it is an user error
sendto is working.
Thanks very much
T
Users browsing this forum: No registered users and 136 guests
