ESPEasy + RFLink + Domoticz as Client
Posted: 15 May 2019, 21:45
Hello.
My problem is the next. I would like to connect my RFLink hardware to my Domoticz server.
The Server is running at home on a Raspberry PI over cable modem-router. The IP is public.
The RFLink hardware is connected to a NodeMCU board. ESPEasy runs on it.
The RFlink is located at an other field, miles away.
There is a Wireless router with 3G connection. The problem, in our country (Hungary) the Mobile internet providers not provide public IP, or not open ports, so i couldn't use it as server or host.
Is there a solution to connect the RFLink Gateway to Domoticz as Client?
-I've tried with Serial-MQTT bridge ->Node-red -> Domoticz, but I'm stuck at The Nodered code, because my low nodered knowledge.
-ESPeasy Ser2net Only works at home or anywhere else with public ip of course.
-I can't edit Domotiz "RFLink Gateway with LAN interface" to works as TCP Server. And espeasy ser2net plugin to works as tcp client.
-I have a new idea. Maybe use the OpenVPN . OpenWRT runs on the 3G router. It's a suddenly idea so I don't know it can be work.
Can anybody help me? Or who has the same trouble?
