(solved)send to and having same device from different esp
riker1
#1 Post by riker1 » 21 May 2019, 12:30
I am wondering if it is possible to distinguish between 2 different devices .
Have 3 devices:
connect all via UDP Port
want to display some status values on ESP1.
ESP 2 and ESP 3 having same device name.
Can they be distinguished?
Or do I need unique device names?
Re: send to and having same device from different esp
#2 Post by grovkillen » 21 May 2019, 13:23
Unique unit numbers?
riker1
#3 Post by riker1 » 21 May 2019, 13:45
sorry, no I mean,
esp1 receiving variable von both ESP2 and ESP3
device#variable names are same on esp2 und 3
How to separate those , showing them on LCD, on ESP1.
is it like:
[ESP2#device#variabe]?
Does this clarify?
T
riker1
#4 Post by riker1 » 21 May 2019, 13:46
grovkillen wrote: 21 May 2019, 13:23 Unique unit numbers?
Unit Numbers are distinct.
Only same UDP Port.
but ...device names and variables ...?
#5 Post by grovkillen » 21 May 2019, 13:53
You need to use the same task numbers on them all, that means you should be able to distinguish them.
riker1
#6 Post by riker1 » 21 May 2019, 14:09
thanks
but I do not understand how?
when you say, task # , this is on ESP1 (receiving)
I have a task there : lcd:
will display
WRC:[status_control#Wifi_Reconnect_Counter]
but
is send by both ESP 2 and ESP 3.
So how to grab the
send by ESP2?
Thanks for clarification.
T
#7 Post by grovkillen » 21 May 2019, 14:58
You need to set up the recieving task/unit to be identical to the sending task/unit and have it send using the ESP Easy controller.
riker1
#8 Post by riker1 » 21 May 2019, 15:17
grovkillen wrote: 21 May 2019, 14:58 You need to set up the recieving task/unit to be identical to the sending task/unit and have it send using the ESP Easy controller.
ok understood, thanks
Users browsing this forum: Ahrefs [Bot] and 11 guests
