I am using a regular 4M nodemcu with the 25/4 mega release.
I have a problem with Syslog.
If I use my device in normal mode (no deep sleep), the syslog server collects data that mirrors the serial log (apart from the stuff before Wifi connects obviously). It's pretty much sent simultaneously
If I use it in the wake time following deep sleep, it either only sends stuff to the syslog server occasionally or not at all.
Any ideas why?
I have tried multiple settings of my device time between reads (a BME280) and different times for the wake time and deep sleep time.
Any suggestions of what has worked for other people?
Thanks very much
SYSLOG priority in sleep/wake
Re: SYSLOG priority in sleep/wake
Hi, my previous post has been up for a while with no comments...
Can anyone point me to a simple tutorial that details the steps to
* set up an esp8266 that goes into deep sleep for 5 minutes at a time
* when it wakes up, it reads from a sensor (e.g. a BME280) and sends this to a syslog server once and then shuts down.
That's all I really want to do, I just need to be able to do it realiably which it isn't at the moment
If syslog is problematic, please let me know!!!
Any help hugely appreciated, I can imagine that this is something that a lot of other people probably want to do too.
Without rules to force an update, device data needs an event (interval or data change) before it is sent to syslog.If I use it in the wake time following deep sleep, it either only sends stuff to the syslog server occasionally or not at all. Any ideas why?
Try this: Enable rules (Tools-AdvancedSettings->RulesSettings). Even with a blank rule file, this trick may help syslog send more messages. If not, then create some rules that perform an action on the data you want to log. I also suggest that you increase the wake time to ensure that syslog has time to fully flush.
I suspect that your special ESPEasy application (deep sleep / syslog) is unique and that the user fan base can be counted on one finger (you). So I think you are in the best position to answer that question.If syslog is problematic, please let me know!!!
Using syslog is not considered a highly robust method of sending important data (it's blind one way communication). The normal solution is to send data by MQTT using rules, which I highly recommend.
Thank you for your help Thomas, I have Rules enabled and I am still experiencing difficulties.
I take your point about Syslog and will use MQTT via Rules and extend the on-time.
Cheers
Cheers
Users browsing this forum: Ahrefs [Bot] and 134 guests
