Hello, I have the following problem: I want to send data via UDP to a Loxone server. But these do not arrive.
Here are the rules:
on Bodenfeuchte#Analog do
SendTo 10.0.1.250,64001,nvalue=[Bodenfeuchte#Analog]
These are the device settings:
(see Screenshot)
And that comes out of it:
752072: WD : Uptime 13 ConnectFailures 0 FreeMem 13296 WiFiStatus 3
757465: ADC : Analog value: 863 = -0.371 (95 samples)
757469: EVENT: Bodenfeuchte#Analog=-0.37
757484: ACT : SendTo 10.0.1.250,64001,nvalue=-0
757493: Command: sendto
767465: ADC : Analog value: 863 = -0.368 (100 samples)
767469: EVENT: Bodenfeuchte#Analog=-0.37
767484: ACT : SendTo 10.0.1.250,64001,nvalue=-0
767493: Command: sendto
777466: ADC : Analog value: 863 = -0.378 (100 samples)
777469: EVENT: Bodenfeuchte#Analog=-0.38
777484: ACT : SendTo 10.0.1.250,64001,nvalue=-0
777493: Command: sendto
782072: WD : Uptime 13 ConnectFailures 0 FreeMem 13264 WiFiStatus 3
787465: ADC : Analog value: 864 = -0.406 (100 samples)
787469: EVENT: Bodenfeuchte#Analog=-0.41
787484: ACT : SendTo 10.0.1.250,64001,nvalue=-0
787494: Command: sendto
797465: ADC : Analog value: 863 = -0.385 (100 samples)
797469: EVENT: Bodenfeuchte#Analog=-0.38
797484: ACT : SendTo 10.0.1.250,64001,nvalue=-0
797493: Command: sendto
So everything seems to be alright (except the ConnectFailures, which I can't explain). Nevertheless, no signal arrives at the server, although the UDP port is definitely the right one.
Does anyone know advice?
Thanks in advance!
Problem with UDP with Loxone
- Bildschirmfoto 2019-06-16 um 12.53.55.png (90.14 KiB) Viewed 5766 times
Re: Problem with UDP with Loxone
Try replacing sendto with sendtoudp
Users browsing this forum: No registered users and 144 guests
