Home Assitant - RFlink - Arduino- Nodo - NodeMCU & Wifi
awesterhoff
#1 Post by awesterhoff » 04 Jul 2019, 20:32
hi!
I am using Home Assistant for a while now and have connected many devices.
I can't get my RFlink with nodo, nodemcu over wifi working.
I flashed the Arduino and the NodeMCU, the NodeMCU is connected to my wifi network
Unfortunatly Home Assistant can't connect.
Home Assistant configuration:
rflink:
# port: /dev/ttyACM0
host: 192.168.1.33
port: 1234
I also have a arduino with rflink connected using USB but have that deconfigured at the moment.
The NodeMCU doesn't have any specific configuration, expect that I configured the home assistant ip as the controller in the nodemcu with port 1234.
Home Assistant is giving me the following error:
File "/usr/src/homeassistant/homeassistant/components/rflink/__init__.py", line 221, in connect
transport, protocol = await connection
File "uvloop/loop.pyx", line 1904, in create_connection
File "uvloop/loop.pyx", line 1883, in uvloop.loop.Loop.create_connection
ConnectionRefusedError: [Errno 111] Connection refused
Who can help me out?
Thanks! AW
