Rule based 12 LED NeoPixel Clock
happytm
#1 Post by happytm » 05 Jul 2019, 23:25
I tried to create 12 led clock using neopixel(basic) and dummy sensor task with quad selected as sensors. I came up with following rules which seems to do the job.I know there must be better way to do it so please correct the rules for better.This demonstrate power of rules engine,plugin system & dummy sensor in ESPEasy. It makes it very fast and easy to make DIY projects without knowing any programming.The hour indicator is red ,minute indicator is flashing blue every 5 seconds which also represent seconds indicator.
on Clock#Time do
timerSet,1,5
TaskValueSet,12,1,%sysmin%/5
TaskValueSet,12,2,[dummy#minutenow]-1
TaskValueSet,12,3,%syshour%
if [dummy#hournow]>12
TaskValueSet,12,3,[dummy#hournow]-12
TaskValueSet,12,4,[dummy#hournow]-1
neopixel,[dummy#hournow],255,0,0
neopixel,[dummy#hourprev],0,0,0
on Rules#timer=1 do
if [dummy#minutenow]=[dummy#hournow]
neopixel,[dummy#minutenow],255,255,255
neopixel,[dummy#minutenow],0,0,255
timerSet,2,1
on Rules#timer=2 do
neopixel,[dummy#minutenow],0,0,0
timerSet,1,5
happytm
Re: Rule based 12 LED NeoPixel Clock
#2 Post by happytm » 07 Jul 2019, 01:10
With some minor adjustment :
on Clock#Time do
timerSet,1,5
if [dummy#hournow]=0
TaskValueSet,12,3,12
neopixel,[dummy#hournow],55,0,0
on Rules#timer=1 do
neopixel,[dummy#minutenow],0,0,55
if [dummy#minutenow]=0
TaskValueSet,12,1,12
timerSet,2,1
on Rules#timer=2 do
timerSet,1,5
