Problem with WEB-interface
Hello!
I have a ESP8266 running with mega-20190630, it was working fine for a couple of days.
It is mounted on my ventilation unit, when I had to cut the power for a while, after that it is like something has happened.
I have it reporting temp values to domoticz, with 5 DHT22 sensors, that is working fine.
But web interface is "kind of" down, just answers with a ring that is spinning, looks like it is thinking or something. I have also a smokeping server that pings devices on my network, and I can see there that something also happened with ping response time, it looks like esp8266 device is overloaded or something, you can clearly see that 10th of July, after my reboot/power outage something happened.
Anyone else had this problem with this release?
Or is it something that may happen when you cut the power, is it possible to bring it back to life without having crawling in to the attic with my laptop?
- smokeping .jpg (90.56 KiB) Viewed 7691 times
Re: Problem with WEB-interface
Tjena! It could be that it is caught in limbo with the WiFi? Could you turn off the wifi for a while and test if the unit start an AP?
Have you tried a remote reboot using http?
http://<DEVICE_IP>/?cmd=reboot
Hallå!grovkillen wrote: ↑13 Jul 2019, 22:41 Tjena! It could be that it is caught in limbo with the WiFi? Could you turn off the wifi for a while and test if the unit start an AP?
That sounds like a reasonable explanation, but I can´t see why it should happen though, because it has managed many reboots before.
I will try it out when I get back home (working night shift right now) and report back!
I have tried a couple reboots with pulling the fuse to the vent unit, and got it to reboot "manually", that dit not work.
But I did try that reboot command, I think that it did reboot, (hard to tell because it misses a couple of ping answers all the time).
Unfortunately, it didn't work.
Thanks anyway!
Hmm, that should have solved the problem. It seems to me that the firmware is corrupted or the device is broken. If it's installed in a hot attic then that can be a cruel environment for cheap Chinese made electronic modules.I have tried a couple reboots with pulling the fuse to the vent unit, and got it to reboot "manually", that dit not work.
Couple more ideas:
1. Reboot the WiFi router. After it is back online, apply power to the ESPEasy device.
2. Try other http commands to check for intelligent life and perhaps learn more about the problem. For example:
http://<DEVICE_IP>/?cmd=settings
http://<DEVICE_IP>/sysinfo
Thanks for your input!ThomasB wrote: ↑14 Jul 2019, 00:33Hmm, that should have solved the problem. It seems to me that the firmware is corrupted or the device is broken. If it's installed in a hot attic then that can be a cruel environment for cheap Chinese made electronic modules.I have tried a couple reboots with pulling the fuse to the vent unit, and got it to reboot "manually", that dit not work.
Couple more ideas:
It does answer on those commands!
If I use sysinfo I come directly to the web interface, and it seems to work, everything except the homepage.
I can also see that it didn´t reboot, and I have tried rebooting it on the reboot button on the interface, and it does not respond on that.
Boot says "Cold boot (0)"
Reset Reason "Power on"
Everything seems to be ok from there, from what I can see, maybe just firmware been corrupted?
Do you think I should try updating firmware from web interface?
Regarding the installation of the ESP unit itself, I am not so concerned, it is installed in the junction box for the ventilation unit, has only been there for a week, I have tried it out on the bench before.
We have had a mild summer until now, I have noted a maximum temperature of 30 degrees celcius in there, and of course it´s also dry in there.
Anything in the sysinfo report to be concerned about? For example, are Free Mem and Free Stack values normal?If I use sysinfo I come directly to the web interface, and it seems to work, everything except the homepage.
That is a good idea. But keep in mind that it won't fix corrupted configuration data. So also try reloading a saved Settings data file too, http://<DEVICE_IP>/uploadDo you think I should try updating firmware from web interface?
Hopefully you find a easy fix. But be prepared to go back in the attic with your laptop. Especially since your 30°C attic sounds like a dreamy vacation spot. Currently 40°C (104°F) in the backyard shade at my place.
I can´t find anything to be concerned about.ThomasB wrote: ↑14 Jul 2019, 01:18Anything in the sysinfo report to be concerned about? For example, are Free Mem and Free Stack values normal?If I use sysinfo I come directly to the web interface, and it seems to work, everything except the homepage.
Here are Free Mem..
Free Mem 15800 (14128 - sendContentBlocking)
Free Stack 3552 (1960 - sendContentBlocking)
I have uploaded the same firmware that it was running, and web interface is back normal.
Ping response is just as terrible as before, but, I have remembered wrong, I did check a little closer about ping response time, and when it did occur, and that was when I moved it to the attic, from my desk.
So theese two faults did not occur at the same time.
It is only ~5 meters from my AP, a roof, and in a metal box on the vent unit, but I guess the wifi antenna on theese units aren´t that strong.
It seems to work ok for now, and I´ll see if it comes back next power outage, or before!
Thanks for your help!
Glad to hear you fixed it.It seems to work ok for now, and I´ll see if it comes back next power outage, or before!
Users browsing this forum: No registered users and 54 guests
