Rules: how to avoid PWM > 1023 ?
costo
#1 Post by costo » 19 Jul 2019, 03:08
I use ESPEasy version 148 talking to a RasPi/Domoticz server with MQTT.
A DS18B20 mounted on a heatsink measures temperature. GPIO-0 with PWM controls a fan that lowers the temp of the heatsink.
The fan should start at about 35C with a minimum PWM value of about 400 and above 75C PWM should always be 1023
Task 1 is a DS18b20 Named DS18 ValueName Temp
Task 4 Dummy Named Fan and ValueName PWM
I wrote this rule:
On System#Boot do
  timerSet,1,15
On Rules#Timer=1 do
  if [DS18#Temp] >35
     TaskValueSet 4,1,[DS18#Temp]*12
     PWM,0,[Fan#PWM]
     TaskValueSet 4,1,0
     PWM,0,0
  timerSet,1,15
The problem is that at above 85C the calculated PWM is >1023 making the fan stop, which should not happen.
What is the solution?
Re: Rules: how to avoid PWM > 1023 ?
#2 Post by ThomasB » 19 Jul 2019, 17:45
The problem is that at above 85C the calculated PWM is >1023 making the fan stop, which should not happen. What is the solution?
Change this:
PWM,0,[Fan#PWM]
To:
if [Fan#PWM]<1023
 PWM,0,[Fan#PWM]
 PWM,0,1023
This code is a nested if/then. I don't believe that old ESPEz versions allowed nesting in rules, so be sure to use a recent MEGA release.
costo
#3 Post by costo » 19 Jul 2019, 21:21
Thomas , thank you for the reply.
As you say, it is a nested it/then/else. As I am using the old V148 this will not work.
I am a bit reluctant to use the mega version. I experience a lot of restarts with the Mega software.
I prefer using the old software so have to find a different solution.
I think a second On/Endon part will do the trick but I am not sure how to define the trigger for a second On/endon.
#4 Post by ThomasB » 19 Jul 2019, 21:43
Does your old version support the Dummy Device plugin? If it does then you can copy the PWM value and limit it to 1023. Use the dummy value in your PWM statement.
As an alternative, you could use the "event" command to handle the PWM action. The event subroutine could limit the PWM value using if/then as shown in my previous post.
costo
#5 Post by costo » 20 Jul 2019, 00:23
Yes I use a dummu device at task 4
I extended the rule with another On/endon which should be triggered at a valuechange of [Fan#PWM]
On System#Boot do
  timerSet,1,15
On Rules#Timer=1 do
  if [DS18#Temp] >35
    //PWM,0,[Fan#PWM]
    TaskValueSet 4,1,0
    //PWM,0,0
  timerSet,1,15
On [Fan#PWM] do
   if [Fan#PWM]>1023
      [Fan#PWM] = 1023
   PWM,0,[Fan#PWM]
I commented out the PWM,0,x lines and added one in the last part but this does not work, the trigger [Fan#PWM] seems to not do anything because the fan is not turning. So the syntax is wrong I believe
#6 Post by ThomasB » 20 Jul 2019, 01:29
This example uses a dummy device at Task #6. Device name FanVar, Value name (1) is PWMval. Feel free to change them for your installation.
On System#Boot do
  timerSet,1,15
On Rules#Timer=1 do
   if [Fan#PWM]>1023
     TaskValueSet 6,1,1023  // Assign max value to FanVar#PWMval.
     TaskValueSet 6,1,[Fan#PWM]  // Copy PWM to FanVar#PWMval.
  if [DS18#Temp] >35
     PWM,0,[FanVar#PWMval]
     TaskValueSet 4,1,0
     PWM,0,0
  timerSet,1,15
costo
#7 Post by costo » 20 Jul 2019, 14:12
Thank you again for the response.
As far as I understand the rules for the old ESPEasy version, it is not possible/advisable/stable to use more than one if/else/enif statement in a On/EndOn rule.
So I had some doubts if it would work So I made a second dummy, not on task6 but on task 3 and tested it.
And it actually works.
So I will see if this rules is stable in the long run.
edit:
This is a little better, only one dummy device , Fan, on task 4 with two variables, PWMset and PWMval.
On System#Boot do
  timerSet,1,15
On Rules#Timer=1 do
   if [Fan#PWMset]>1023
     TaskValueSet 4,2,1023  // Assign max value to Fan#PWMval.
     TaskValueSet 4,2,[Fan#PWMset]  // Copy PWMset to Fan#PWMval.
  if [DS18#Temp] >30
     TaskValueSet 4,1,[DS18#Temp]*12  // Calculate PWMset
     PWM,0,[Fan#PWMval]
     TaskValueSet 4,1,0
     PWM,0,0
  timerSet,1,15
#8 Post by ThomasB » 20 Jul 2019, 18:24
Glad to hear you solved the problem.
Users browsing this forum: No registered users and 123 guests
