seemed to be missing the "IDX" field in my setup. I have seen other screenshots with the IDX field. Am I doing something wrong?
Thanks,
Missing IDX on DFPlayer
Re: Missing IDX on DFPlayer
The plugin got no values so it will not broadcast anything, thus no need for IDX?
I want to control the player with Domoticz, different sounds for different situations. According https://www.letscontrolit.com/wiki/index.php/MP3_player it should be possible with MQTT. I thought that I should have an IDX for MQTT?
No you don't use IDX for that, use rules and publish (preferably) events which the unit then act upon.
As far as I know, the IDX value is only used on sending sensor values to a controller.
