Homie Receiver P086 ~ Can I use their stored variables in formulaes?
JR01
#1 Post by JR01 » 17 Aug 2019, 21:27
Hi, thanks for the Homie Receiver - it works well. I can set their values (if not String) with a mqtt message, an example - sending a 1 to
homie/ESP62DEV/homieRec3/durLeg1/set
I would like the use the variables from the Receiver in Rules, but it does not seam to work:
on homieRec3#durLeg1 do
   // code
Was this outside of scope of the Plugin?
IOTPLAY. Tinkerer, my projects are @ http://GitHub.com/IoTPlay . Using RPi, Node-Red, ESP8266 to prove Industry 4.0 concepts.
HarpieC
Re: Homie Receiver P086 ~ Can I use their stored variables in formulaes?
#2 Post by HarpieC » 13 Sep 2019, 18:10
sorry for come back to you so late. I`m not very often on the forum (more scanning github) I currently working on an updated version of the homie plugins and a full features custom homie node for Node-RED
please try to use
on durLeg1 do
instead of
I plan a new pull request soon with a lot of updates, bugfixes including storing the values (except strings). Access to the variables should work with
[homieRec3#durLeg1]
but I'm not sure if the current version can do this. Now I think I will change the naming scheme to device#property to be consistent with other plugins.
Hope this helps, Chris
JR01
#3 Post by JR01 » 15 Sep 2019, 12:26
Thank you Chris, no
- in my tests does not work.
Per your reply to my other post, I also need the variables to not be stored in float by default, but if I pass the var as integer, which I need in the clock event.
Thank you, looking forward to the pull request for P086 !
