http send command or rule
ingoiot
#1 Post by ingoiot » 21 Aug 2019, 21:43
hi,
i tried to send a http command to a Smartplug to switch it on and off with an app.
http://192.168.178.33/control?cmd=GPIO,14,0 works to switch the relais,
but i also want to swicht a status led. can i send 2 commands in one request?
i already have a rule that switches both relais and led with a physical button. can i trigger it per http?
on Button#state do
  if [Relais#state]=0
    gpio,14,1
    gpio,13,0
    gpio,14,0
    gpio,13,1
i tried http://192.168.178.33/control?cmd=event,%20Button=1
but it doesnt work. the esp receives the message but doesnt react.
111809: HTTP: event, Button=1
111861: EVENT:  Button=1
Re: http send command or rule
#2 Post by ThomasB » 21 Aug 2019, 22:25
A typical solution would be like this:
on Button#state do
  if [Relais#state]=0
    event,RelayOn
    event,RelayOff
On RelayOn do
  gpio,14,1
  gpio,13,0
On RelayOff do
  gpio,14,0
  gpio,13,1
The http command to turn on your Relay & LED would be:
http://IP_ADDRESS/control?cmd=event,RelayOn
ingoiot
#3 Post by ingoiot » 21 Aug 2019, 23:18
tnx,
seems to work.
strangely it looks like if i`m triggering the event through the app the esp react relatively fast,
through the webbrowser it seems to slow down the esp quite a bit.
#4 Post by TD-er » 22 Aug 2019, 10:41
What do you mean by "the app" ?
ingoiot
#5 Post by ingoiot » 22 Aug 2019, 16:58
i`m using an app to send the http request HTTP Request Shortcuts
when i send the command with this app, it switches pretty quick,
if i use a browser it reacts pretty slow.
(maybe the browser keeps state and blocks up the esp? dont know)
#6 Post by grovkillen » 22 Aug 2019, 18:40
If you surf in to the unit the unit has to do a ton more compared to when you just send a simple http request.
PS. you're use of that app suggests to me that you have the unit exposed to the internet?
ingoiot
#7 Post by ingoiot » 22 Aug 2019, 18:53
grovkillen wrote: 22 Aug 2019, 18:40 PS. you're use of that app suggests to me that you have the unit exposed to the internet?
no, i dont think so.
at least it have only entered a local ip..
#8 Post by grovkillen » 22 Aug 2019, 19:46
Aha, so it's only working when at home or connected through VPN?
ingoiot
#9 Post by ingoiot » 22 Aug 2019, 19:56
yes, thats enough for me for the moment.
maybe i try to get the temperature via http - dont know if that would work.
ingoiot
#10 Post by ingoiot » 22 Aug 2019, 22:28
not sure if this fits this thread or if i should open a new one..
but when i try to send the command through the esp peer network,
it does not work.
sending esp rule:
On ds18b20#Temperature Do
 If [ds18b20#Temperature]>-15
 sendTo,1,RelayOn
EndOn
gives
345820: Command: sendto
360794: DS   : Temperature: 17.50 (xx-2-0-x-9a-xx-1-zz)
360798: EVENT: ds18b20#Temperature=17.50
360814: ACT  : sendTo,1,RelayOn
360821: Command: sendto
receiving esp rule as above
on Button#state do
  if [Relais#state]=0
    event,RelayOn
    event,RelayOff
On RelayOn do
  gpio,14,1
  gpio,13,0
On RelayOff do
  gpio,14,0
  gpio,13,1
log:
340900: Command: relayon
340900: Command unknown: 'relayon'
355892: Command: relayon
355892: Command unknown: 'relayon'
#11 Post by grovkillen » 23 Aug 2019, 05:43
You forgot to use the command event.
sendTo,1,Event,RelayOn
ingoiot
#12 Post by ingoiot » 23 Aug 2019, 16:15
tnx, now it works :)
Users browsing this forum: No registered users and 142 guests
