Get PWM value in any way
darkchris90
#1 Post by darkchris90 » 27 Aug 2019, 19:30
is it possible to get the current PWM status in the version 20190817? I need it for fhem. In some early versions it was in the state variable but now there is only 0,1,-1 and sometimes -2.
Where can I change the source code to get the value? I changed the code on my own and tried to modify the globalMapPortStatus directly or with the function savePortStatus. I prepared a struct which has the PWM value in the state and the output variable, but it doesnt work. I also changed the type of state to uint16_t like in the older versions.
Re: Get PWM value in any way
#2 Post by grovkillen » 27 Aug 2019, 20:00
I use a custom event and send the wanted value, which I store as in internal variable as well as setting the pwm.
So conclusion, you cannot get the value any other way currently.
darkchris90
#3 Post by darkchris90 » 27 Aug 2019, 20:43
Good evening,
thank you for the fast answering. Can you explain the custom event and how to use it?
#4 Post by grovkillen » 28 Aug 2019, 07:34
Using rules you create an event using the event command.
https://espeasy.readthedocs.io/en/lates ... Rules.html
darkchris90
#5 Post by darkchris90 » 28 Aug 2019, 20:55
Ah ok, I thought you talked about something in the code, because of the internal variable. I will try it. Thank you!
Cdzn
#6 Post by Cdzn » 05 Sep 2023, 17:42
How to store adn read PWM to/from Dummy values?
I read this but can`t understand syntax. What exactly used here and what not
For any plugin that registers the used pin(s), the last set pin state can be retrieved, either regular pin state or PWM state, by using this syntax: [Plugin#<pluginId>#Pinstate#N]
Also where i can find plugin and pluginid?
#7 Post by TD-er » 05 Sep 2023, 18:05
See the documentation on referring to the pinstate of a specific pin:
https://espeasy.readthedocs.io/en/lates ... task-names
And some example here: https://espeasy.readthedocs.io/en/lates ... tem-events
You need to scroll to the "Matching events" section as the example is at the end of the section above it.
chromo23
#8 Post by chromo23 » 05 Sep 2023, 18:08
Cdzn wrote: 05 Sep 2023, 17:42 How to store adn read PWM to/from Dummy values?
To put a value in a dummy device use taskvalueset:
https://espeasy.readthedocs.io/en/lates ... skvalueset
The pwm value you would get with:
[Plugin#GPIO#Pinstate#12]
...assuming your GPIO is 12
As also discussed here: viewtopic.php?t=9801
So to write to a dummy device simply use:
TaskValueSet,<name_of_dummy_device,<value_name>,[Plugin#GPIO#Pinstate#12]
To read the value use:
[<name_of_dummy_device>#<value_name>]
e.g.:
 LogEntry,'[MyDummy#MyValue]'
Cdzn
#9 Post by Cdzn » 05 Sep 2023, 18:19
This is what i can`t understand) I though should use "status,g,5" in command line or something! Thanks a lot. I have PWM fan and wanted to store and restore the last duty.
Cdzn
#10 Post by Cdzn » 07 Sep 2023, 05:00
Stil can`t get success.
I wrote 3 rules
1st for restore the last PWM value:
on System#Boot do
  PWM,5,[TestMemory#Dummy]
2nd for triggering pwm:
on pwm do
  PWM,5,%eventvalue1%
  //Publish %sysname%/GPIO/GPIO5,[Plugin#GPIO#Pinstate#5]
3rd when the PWM changing duty this should store in memory last value:
on pwm#state do
  TaskValueSet,TestMemory,Dummy,[Plugin#GPIO#Pinstate#5]
When i push the button with this code
http://192.168.0.123/control?cmd=event,PWM=1023
fan start spining at max speed and should store this value in Dummy device, but it`s empty.
Cdzn
#11 Post by Cdzn » 07 Sep 2023, 05:50
I guess this is not working because the PWM#State is still 0 and did`t change value when u call it via http. This is why taskvalueset wont work. I could see changes in logs but i dunno.
Micha_he
#12 Post by Micha_he » 07 Sep 2023, 06:30
Maybe, because evantname and command are the same !?
#13 Post by TD-er » 07 Sep 2023, 08:31
When in doubt whether events are handled and if so with which eventvalues, you can always use "logEntry" to create logs.
on pwm do
  PWM,5,%eventvalue1%
  logentry,"On pwm Do: EventValue: %eventvalue1% PinState: [Plugin#GPIO#Pinstate#5]"
And please note that rules parsing ends when a matching event is found.
So if "on pwm do" is before "on pwm#state do", the latter one may not be processed. (not 100% sure this is the correct example, but you get the idea)
chromo23
#14 Post by chromo23 » 07 Sep 2023, 09:12
Cdzn wrote: 07 Sep 2023, 05:00 2nd for triggering pwm:
Why not combining these two?
Like:
On pwm Do
  PWM,5,%eventvalue1%
  TaskValueSet,TestMemory,Dummy,%eventvalue1%
  //Publish %sysname%/GPIO/GPIO5,%eventvalue1%
Cdzn
#15 Post by Cdzn » 07 Sep 2023, 09:16
Micha_he wrote: 07 Sep 2023, 06:30 Maybe, because evantname and command are the same !?
Nope, coz this only rule is working fine, except others. command successfully executed when i send the duty cycle. But it wont save value in dummy
Cdzn
#16 Post by Cdzn » 07 Sep 2023, 10:00
chromo23 wrote: 07 Sep 2023, 09:12
Like:
On pwm Do
  PWM,5,%eventvalue1%
it`s working. YAASS))
Td-er was right, i guess there problem was in sequence.
Thank You all for help!
Users browsing this forum: Ahrefs [Bot] and 9 guests
