Rule for watering cycles
I start with the rules and I need your help to understand.
I would like with the instruction "On Clock # Time = All, 22:00 o'clock" to launch 5 launch loops of 3 watering zones (2 min each).
I can do Zone 1 ON and zone 1 OFF
on Clock # Time = All, 22:00 pm
Launch cycle 1/5:
* Launch Zone 1 on for 2 minutes (zone 3 off)
* Launch Zone 2 on for 2 minutes (zone 1 off)
* Launch Zone 3 on for 2 minutes (zone 2 off)
Then same thing cycle 2/5
Then same thing cycle 3/5
Then same thing cycle 4/5
Then same thing cycle 5/5
Can you help me ? or orient myself.
Thank you
Launch cycle 1/5:
Thank you
Sigalou
Utilisateur/Développeur Plugin Jeedom
Créateur des plugins Alexa-API & WatchDog
- Site perso dédié domotique : Sigalou-domotique
- Support : Alexa-API WatchDog
- Documentation, Changelog et Todo-List : Alexa-API WatchDog
Re: Rule for watering cycles
Please have a look at using timers: https://espeasy.readthedocs.io/en/lates ... g-examples
Thank you for your advice, I went to see and sought to understand.
Hello friends, here's what I did, it works. Do you think we can do more simple?
Thank you for your valuable advice.
on Clock#Time=All,22:00 do
let,1,1 // compteur de boucles (de 3 zones) de 1 à %v2%
let,2,5 // nombre de boucles (de 3 zones)
let,3,120 // temps d'arrosage de chaque zone en secondes
timerSet,5,1 //Initialise le Timer 1 à 1s
gpio,15,1 // Relais4=ON
On Rules#Timer=5 do // Zone1=ON // Zone3=OFF
gpio,12,1 // Relais1
gpio,4,0 // Relais3
timerSet,6,%v3% // Lance timer 2 dans %v3% secondes
On Rules#Timer=6 do // Zone1=OFF // Zone2=ON
gpio,12,0 // Relais1
gpio,5,1 // Relais2
timerSet,7,%v3% // Lance timer 3 dans %v3% secondes
On Rules#Timer=7 do // Zone2=OFF // Zone3=ON
gpio,5,0 // Relais2
gpio,4,1 // Relais3
timerSet,8,%v3% // Lance timer 4 dans %v3% secondes
On Rules#Timer=8 do
if %v1%<%v2% do
let,1,%v1%+1
timerSet,5,1 //Lance timer 5
gpio,15,0 // Relais4=OFF
gpio,4,0 // Relais3
Sigalou
Looks quite clean to me, but I'm not the expert on rules here
Glad to see you came up with this by just reading the docs. So apparently those are really helpful so it seems.
Thumbs up from me. That's clean
- dynamicdave
The only comment I would make (from my experience of using 'rules') would be to place the timerSet,5,1 as the last statement.
i.e. interchange the position of timerSet,5,1 and gpio,15,1
On Clock#Time=All,22:00 do
Yep,, thanks Dave, it's good practice to do so.dynamicdave wrote: ↑03 Sep 2019, 10:30 The only comment I would make (from my experience of using 'rules') would be to place the timerSet,5,1 as the last statement.
On Clock#Time=All,22:00 do let,1,1 // compteur de boucles (de 3 zones) de 1 à %v2% let,2,5 // nombre de boucles (de 3 zones) let,3,120 // temps d'arrosage de chaque zone en secondes timerSet,5,1 //Initialise le Timer 1 à 1s gpio,15,1 // Relais4=ON endon
Merci à tous, thank you all
Sigalou
Users browsing this forum: Amazon [Bot], Bing [Bot] and 55 guests
